OEM Blade/Pin SDA cable
i am looking for a Polk Audio SRS 3.1 blade/pin interconnect cable. Would appreciate the help locating a cable.
    F1nut Posts: 52,406
    edited August 13
    For an original keep checking eBay.
    A lot of us get rid of the pin/blade cable and sockets. We replace with high quality speaker cable and Neutrik SpeakOn connectors/sockets. There's plenty of info here on that.
  • tfulton7
    tfulton7 Posts: 2
    Thanks, where can i go to figure out how to replace the pin/blade
    billbillw Posts: 8,287
    Search at the top for SDA Speakon. It should give you lots of information. Here is one post from one of our most respected SDA mod guys, RIP sadly.
    https://forum.polkaudio.com/discussion/comment/2208422#Comment_2208422
    audioluvr Posts: 6,079
    I believe the signal is only sent via the pin so you could use a single strand of good quality copper speaker wire and install a good quality banana terminal. Don't quote me on this as I'm sure someone on here will correctly profusely if I'm wrong.
  • Unknown
