Lsi25 schematic
hmagallon1
Hi everyone,
I recently picked up a pair of LSi25s and I'm in the process of restoring/upgrading them. I've searched the forum and online but haven't been able to find the crossover schematic.
Does anyone happen to have the LSi25 crossover schematic (especially the mid/tweeter crossover), or know where I can download it?
I'd really appreciate any help. Thanks in advance!
Answers
Should be able to find them here.
https://forum.polkaudio.com/discussion/38755/polk-audio-speaker-wiring-schematics-more-all-models-except-sda#latest
Never mind I see that during the transition something went wrong.
@SeleniumFalcon, @Ryan_Soundunited do you have a suggestion on the recovery of the LSi25 page? -
I see the issue, let me see what I can do to fix it. It may take some time but I will work on repairing the links. -
So it seems some of those links are broken, I am working with Kim and some others on the backend to find these legacy schematics so I can re-upload them onto that page for future use.
Ryan_Soundunited wrote: »So it seems some of those links are broken, I am working with Kim and some others on the backend to find these legacy schematics so I can re-upload them onto that page for future use.
EXCELLENT my man! -
hmagallon1, remove a crossover and you will find the values printed on the capacitors and resistors.Political Correctness'.........defined
President of Club Polk -
Thanks. I've already removed the crossover and documented the component values. F1nut... What I'm looking for is the actual schematic so I can understand the circuit topology and how everything is connected. I want to build a new crossover using higher-quality components and possibly a new layout rather than reusing the original PCB. Without the schematic, I don't know the exact electrical connections or filter topology, and I don't have the experience to reverse-engineer the board from scratch. If anyone has the LSi25 schematic, or even the crossover drawing, I'd really appreciate it. And thank you all for working on the broken links.
Hi everyone,
I found the schematic I was looking for. Thank you all for taking the time to help and point me in the right direction. I really appreciate it.
I'll post it here as well in case anyone else needs it in the future. Thanks again! -
