SDA 1c & SDA 2b nib...
Hilsquad
How do I go about inspecting, testing?
Those speakers were never shipped with plastic bags around the boxes.
Most importantly, make sure your amp is common ground.Don't take experimental gene therapies from known eugenicists.
I realize that, I wrapped them in plastic and placed mothballs in the plastic to keep moisture and bugs out. -
Presuming from previous posts that you have already purchased these?
Probably high on the list of considerations would be getting the magnets glued, if after testing drivers for smooth, non-binding travel, all are good.
Careful with transport until then, and keep them on their backs.
I disabled signatures. -
The plastic wrap will possibly create and keep moisture in and your speakers will definitely now stink!!! -
I like to go with dessicated bones. I make them in my basement.
Scratch that. Most importantly, don't f*rt in the bag before sealing it up.Don't take experimental gene therapies from known eugenicists. -
Especially not a wet one.George / NJ
Onkyo A-8017 integrated
iFi nano iDSD DAC
iPurifier3
iDefender w/ iPower PS
