Polk lsim book shelf, blown crossover, need help to ID replacement parts
LessOpinion
in Speakers
I cannot read the resistor values. what I think is called a inductor (wire wound iron) next to it is not labeled with any info. Can you suggest up grades!
Answers
If you pull the crossover from your other speaker you'll be able to see the resistor values.Political Correctness'.........defined
President of Club Polk -
Maybe? Its blown also, I haven't looked yet.
this is really uncommon for that model... what caused the issue? You had some serious juice to cook that big resistor there- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
I'm guessing an amp went bad and sent DC through the speaker cables. He might have other issues when it comes together.
Polk has forked up the schematics pages. We used to have one thread for SDA and one for all other speakers. The LSim speakers were in one that was for ALL others. I cannot find it now to save my life. I'm sure what you need is in there IF you can find it.
Post edited by pitdogg2 on -
https://forum.polkaudio.com/discussion/38755/polk-audio-speaker-wiring-schematics-more-all-models-except-sda#latest
I guess it is NOW in the "Advanced Technical" section
https://forum.polkaudio.com/categories/schematics
