Had to fix AC Unit
Toolfan66
Toolfan66 Posts: 18,412
So our AC Unit went down the other day, easy fix really, had to pick up a Coil Contactor, and a Capacitor. It was a bad Contactor, but changed the Capacitor while I was there.
I picked them up from Charles D for $26.45
How is it cheaper for me to fix our AC Unit, than it is for the two of us to eat at Culver’s? Or even Chick-Fil-A..
I could only imagine what it would have cost us, had I called someone out to fix our AC unit though.
    billbillw Posts: 8,195
    Probably a $250 service visit. They would charge triple for the parts too.
    VR3 Posts: 29,731
    Depends on if it's a private equity op or a regular mom and pop
    Pe maybe 650 to 700... Mandp 250 to 300
    SCompRacer Posts: 9,385
    Good job! I did ours a few years ago. If you have the skills and know how to prevent hurting yourself, you can save $$ with DIY and take the wife out to a nice place with cloth napkins. ;) I also shut off power and pop the top fan unit off (have to disconnect fan wires) and clean the coils every year.
    mhardy6647 Posts: 35,554
    So did you go for a nice cap like a Clarity Cap or a Mundorf, or cheap out and go with a Solen or Dayton/Bennic?
    ahem.
    :blush:;)
    Viking64 Posts: 7,803
    ahem.
    :blush:;)
    At $26.95 he didn't get a Clarity PUR for the Purity, that's for sure... :D
    Well... maybe on the second-hand market... just hope he didn't order one from AliExpress...
    edited July 19
    I'd just like to point out that the post above contains three sets of ellipses (none actually used, technically, correctly), a hyphen, and an emoji.
    BINGO!
    edited July 19
    If you have the knack to fix them, just ensure you use a "My Sharona" rated capacitor.
    "Ooh, you make my motor run, my motor run........." :D
    Apologies if I got that stuck in your head now....
