Had to fix AC Unit
Toolfan66
So our AC Unit went down the other day, easy fix really, had to pick up a Coil Contactor, and a Capacitor. It was a bad Contactor, but changed the Capacitor while I was there.
I picked them up from Charles D for $26.45
How is it cheaper for me to fix our AC Unit, than it is for the two of us to eat at Culver’s? Or even Chick-Fil-A..
I could only imagine what it would have cost us, had I called someone out to fix our AC unit though.
Probably a $250 service visit. They would charge triple for the parts too.See profile for rigs. Nothing else here.
Depends on if it's a private equity op or a regular mom and pop
Pe maybe 650 to 700... Mandp 250 to 300- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Good job! I did ours a few years ago. If you have the skills and know how to prevent hurting yourself, you can save $$ with DIY and take the wife out to a nice place with cloth napkins.
I also shut off power and pop the top fan unit off (have to disconnect fan wires) and clean the coils every year. Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
So did you go for a nice cap like a Clarity Cap or a Mundorf, or cheap out and go with a Solen or Dayton/Bennic?
ahem.
mhardy6647 wrote: »So did you go for a nice cap like a Clarity Cap or a Mundorf, or cheap out and go with a Solen or Dayton/Bennic?
ahem.
At $26.95 he didn't get a Clarity PUR for the Purity, that's for sure...
Well... maybe on the second-hand market... just hope he didn't order one from AliExpress...
I'd just like to point out that the post above contains three sets of ellipses (none actually used, technically, correctly), a hyphen, and an emoji.
BINGO!
If you have the knack to fix them, just ensure you use a "My Sharona" rated capacitor.
"Ooh, you make my motor run, my motor run........."
Apologies if I got that stuck in your head now....Post edited by SCompRacer onSalk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 *
