Completely Hypothetical Question
kevhed72
I was just relaxing and thinking about my day, when this purely hypothetical, curious question popped in my head. If one was so inclined, how could they crash or shoot down someone else's drone....say in a residential area. Just wondering, for no particular reason at all.
It's a federal offense, regardless.
You do not own the sky/air path above your property. The FAA does. There will be flight logs on the drone or transmitted from the drone.
Shotgun works well.
https://www.goodiesrc.com/can-someone-shoot-down-your-drone/
I saw on a cop show out in I believe Arizona where a guy kept flying a drone low over his neighbor's house. The neighbor got fed up and shot it down. The cops didn't do anything with the shooter due to IIRC the fact the drone was being flown too low.
There are definitely rules for that.Deleted User wrote: »There’s no way I’m watching one of those things hover over my head or near a window without doing something.
Trust me I get it!
Bird shot works swell.
Can't legally discharge a firearm within 500' of a residence so that rules that out. Maybe a wrist rocket slingshot or a high powered pellet gun (both available at walmart) if the bad machine in the air won't go away. Or maybe a laser pointer might work to blind it enough that it would crash?
FWIW I don't condone destroying a drone and would rather let it go away on it's own rather than face legal consequences. I believe that's a given; there will be consequences if one decides to take out a drone. -
We had our bad ash “back to the Fifties “ weekend this last weekend at the state fairgrounds. Second largest car show in the USA. There were signs that said “ No Drones” over the grounds.
Cannot verify, but the rumor was two that violated the airspace were taken care of with a wrist rocket devise. Cannot verify. Just a funny rumor. Peace. DMIT Magnum MH-750, Monster HTS 5100MKII, Sony 77" Class - A80CJ Series - 4K UHD OLED,PS4, Def Tech 15” sub,LSIM 706c, Sunfire Signature Grand 425 x 4,Parasound hca 120, LSiM 702 x 4, Oppo 103D, SDA SRS 1.2, Pioneer Elite SC63 , Pioneer Elite BDP-05 “Why did you get married if you wanted big speakers?” -
mhardy6647 wrote: »Raptors.
I was still in high school when Blondie released their version of that. -
A higher tech solution would be a WiFi blocker. If the drone has RTH (return-to-home if signal is lost) then a GPS frequency blocker might also be needed to down it. Both of these devices are probably illegal in most places.
Rumor has it that some USPS hubs including Palmetto, GA are using WiFi and/or cellular blocking to *try* to keep the employees productive.Expect that there will be bumps in the road. Choose to not let them rattle you.
Boston - CR7, CR6s, CR4s.
Thompson Adventures, Inc. -
non hypothetical video
https://www.youtube.com/watch?v=IrocytwdeEY&t=1s George / NJ
Onkyo A-8017 integrated
iFi nano iDSD DAC
iPurifier3
iDefender w/ iPower PS
As pretty much already mentioned, in a suburban environment with houses close together, it would be pretty ill advised to discharge a firearm.
You would have to get a bit more inventive with something like a slingshot (even then you need to be really careful of where that shot is coming back to earth), or something that disrupts the electronics.
In a rural environment, like my cabin property, I would be happily putting my trap skills to work. I could even stage it as an accident by tossing some clays up near the drone...
a compound bow and arrow might be fun.
Of course, there's always Annette.
umm, I mean... a net. -
Roman Candle with 12 shots increases targeting probabilities.Don't take experimental gene therapies from known eugenicists.
in places where fireworks are legal (e.g., here) that might give one some plausible deniability...
Up here in the stix it would be double barrel 20ga. for the Mrs and single shot 12ga. for me, see who can hit it first. My $$ is on me
Yep, my name really is Bob.
Rogue Audio Conus Magnum iii Dark, Denon DP1200 w/Shure V15 Type V and Jico SAS stylus, Marantz UD7007, Polk L600, Rythmik L12 sub. -
Dem drone varmints ain't got nuttin' on ol' Jed...
Don't take experimental gene therapies from known eugenicists. -
Trebuchet, pumpkins, and M-80s to make biodegradable flak?
Your story is that you are assisting your neighbors with composting via an air delivery system. You can't help it if a drone isn't watching where it's going.
I disabled signatures. -
[emphasis added]Trebuchet, pumpkins, and M-80s to make biodegradable flak?
Composting. By gum, it's our civic duty in the 21st Century! -
PS I think I saw a group on Bandcamp called Biodegradable Flak.
