12 gauge wire
NJHifi
NJHifi Posts: 11
edited June 6 in Vintage Speakers
Hi-
I have a pair of Monitor 5jr. speakers— 2 way with front port.
I just bought some new 12 gauge wire and have it wrapped around the terminal posts but it’s so think the connections aren’t very tight.
It sounds fine but wondering if anyone has any suggestions for making them more secure. The wire is too heavy to thread through the pinhole— I know Polk originally recommended 16 gauge and I replaced old 18 gauge.
Thanks in advance.
  • ken brydson
    ken brydson Posts: 9,103
    NJHifi wrote: »
    Hi-
    Thanks in advance.
    Install bananas or spades...
    F1nut Posts: 52,406
    Banana plugs
  • NJHifi
    NJHifi Posts: 11
    Thank you both. I will try one. The speakers seem to sound better with the new wire but not sure if it’s my imagination.
    Tony M Posts: 12,018
    I'm pretty sure they sound better now.
    Just think if you used $$$$$ wire...who knows what those Polk 5jrs would sound like.
  • odcics2
    odcics2 Posts: 396
    If you use $$$$$ wire, remember to tell the electrons.
    https://ethanwiner.com/audiophoolery.html
    F1nut Posts: 52,406
    ^BS!!!^
  • NJHifi
    NJHifi Posts: 11
    edited June 8
    The 12 ga. wire I used was pretty cheap. LOL Wirecutter recommended and used on Amazon (Someone had returned it?)
    I found an old Stereo Review article; it said the testers preferred 16 ga. to 22. back at the beginning of “status” wire brands. But advised against over paying for wire.
    I’ll read the one you posted from Ethan Winer, too.
    F1nut Posts: 52,406
    edited June 8
    This is real world experience from folks here that didn't spend any of their money (other than shipping costs) to demo some cables in their rig. So, forget that over used expectational bias or the cables are cables crap that naysayers love to spout.
    https://forum.polkaudio.com/discussion/129583/mit-shotgun-s3-3-cable-demo-review-round-4
    There are many other cable demo threads here for your viewing pleasure, so get your search on.
    Edit: buying cables strictly by the gauge of it is not how one should buy cables.
  • Emlyn
    Emlyn Posts: 4,905
    It's pretty easy these days to find a decent pair of 10 ft copper speaker cables pre-terminated with soldered on banana connectors for around $40. They can last for decades.
    audioluvr Posts: 6,079
    Big question is, will there be an audible difference with $5,000 speaker cables listening through an old pair of 5jr's powered by a hello kitty boom box receiver.
    treitz3 Posts: 20,360
    Probably, but negligible. Money would be better spent improving other areas of that type of system, rather than jumping straight to a 5K cable.
    F1nut Posts: 52,406
    edited June 9
    audioluvr wrote: »
    I used cables in that price range on speakers with an MSRP around $1000.00, but with upstream gear much better than a boom box. The cables made an absolutely obvious improvement.
  • NJHifi
    NJHifi Posts: 11
    I have a Marantz PM 7000. The spool was $30 bucks.
    I found that I could secure the 12 gauge after all without the banana plugs or lugs but these were good ideas.
    I’m basically the original owner of the vintage Polks— my dad bought them from my uncle when I was 15. My uncle loved gear and had bought them for his kitchen and paired them with a Nakamichi SR-2A but wanted something else. So he sold us the gear.
    The Polks still sound great. I had the Nakamichi years ago until it gave out- it was a great little receiver. The Polks sound good on my PM7000.
    This is a great forum and hope Polk keeps it running.
  • Unknown
  • SeleniumFalcon
    SeleniumFalcon Posts: 4,386
    There used to be a theory concerning speaker wire that from about 600Hz and below what was important was the electrical resistance. The lower the resistance the better, hence thicker cables. But, for 600Hz and higher what was important was the inductance of the wire not the resistance. This meant that some sort of winding technique was needed to lower the inductance with a result in increasing the capacitance. They are the yin and yang of using wire as conductors. This was the era of Polk's Cobra Cables and unfortunately solid state amplifiers can have problems driving capacitive loads so they fell out of favor. I believe they are highly sought after in Japan.
  • Unknown
    F1nut Posts: 52,406
    edited June 10
    Yep, there's a lot more to better cables than the material used and the gauge.
  • aprazer402
    aprazer402 Posts: 3,463
    Federal, Winchester, Remington, Hornady... agree too!
  • kinglouie
    kinglouie Posts: 4
    That was the basis of audioquests SST(spread spectrum technologies) thicker conductors for lower frequency and thinner but more conductors for higher frequencies.
  • kinglouie
    kinglouie Posts: 4
    This is vaguely what I remember the salesman telling me when I bought my speakers back in the '90s. Something along the lines of a thicker wire wrapped with a thinner wire for the different frequencies.
  • skrol
    skrol Posts: 3,493
    edited June 17
    Going from 18 awg to 12 awg, you probably did. notice a true difference. This is especially true for long runs. I had started out with 18' runs of (caugh caugh) Monster Cable XP (they don't say but seemed like 16 awg) from BB because it was affordable, it seemed better than regular lamp cord and I was a skeptic about fancy speaker cables.
    I thought about upgrading to 12 awg or maybe 10 awg Blue Jeans but found a great deal on bulk AudioQuest SLiP DB 2/14, which is nothing too fancy but is 14 awg, plus it looks better and is a more boujee brand than Monster. I also relocated my amp to shorten the run to 12'. I figured it might be a little louder and maybe a little more bass control given the lower impedance benefitting the damping factor but wasm't really expecting anything. To my surprise, the bass did tighten up, and the sound stage opened a bit. The biggest benefit was that I now liked my LSi15 that I struggled to convince myself that they sounded good and thought of getting rid of them. The bass that always seemed disconnected from the top end now integrated nicely. So I'll keep them.
    Everything matters. The question is, how much?
    Stan
    Main 2ch:
    HT:
    Other stuff:
