Vintage Monitor and SDA Speaker Deals
Worth experimenting on.
What MWs did they come with?Don't take experimental gene therapies from known eugenicists. -
MW6600 or MW6501
Mine was the SDA1 signature and they came with MW6600 in all spots except the dimensional spot, it was MW6501. Later models came with all MW6501. I'm fairly sure the MW6501 and MW6600 were identical in specs. I ran one speaker with all MW6600 and the other with MW6501, I could tell zero difference.
Boy, Edwin from Polk Customer service sure fouled up the response. He gave info on the SDA1b, which they are NOT! Polk CS sure has fallen way down the mountain. -
I must admit, the electric socket for the interconnect is genius
Ive looked for that model before just to make a tweeter plate to go center of all the mids and have a listen.Don't take experimental gene therapies from known eugenicists.
The original SDA1 with ports also had boxes inside the cabinet built around the top drivers. There was papers in the vintage speaker section that walked you through the removal of the boxes and plugging the ports to turn the SDA1 into the SDA1a. Your best bet to do what you would like is to look for the SDA1a. There would be a ton less work involved and a LOT less glue to scrap out. My .02 -
Good info.
Id just sawhole the center and drop in a round bezel using the stereo tweeter circuit.
If I liked what I hear, then pretty er up.Don't take experimental gene therapies from known eugenicists. -
Polk Audio SDA Compact System Speakers Pair Left Right
Currently listed at shopgoodwill.com starting bid $49.95
https://shopgoodwill.com/item/263067527
local pickup only in San Diego
The arc of the moral universe is long, but it bends towards justice.—Martin Luther King Jr. -
I wouldn't touch them with a ten foot pole. Those are trash.
Sell the 6511's and double your investment lol.Don't take experimental gene therapies from known eugenicists.
1. If they had mw6511 you're dreaming that they will be good.
2. They came with 2 mw6503
3. You should know this.
Can't tell what iteration they are. Sell the 6503's and quadruple yer duckets then.
The cabs look a tad better than the first set I stumbled upon lol.Don't take experimental gene therapies from known eugenicists. -
Blade/blade interconnect CRS
https://www.facebook.com/marketplace/item/964715189505238/?ref=browse_tab&referral_code=marketplace_top_picks&referral_story_type=top_picks
Look like 2B's, good price, me thinks!
No affil.
LSi9s - $250 (waltham) No affiliation. Define "excessive" LOL.
https://boston.craigslist.org/bmw/eld/d/waltham-polk-audio-lsi9-bookshelf/7936440914.htmlExpect that there will be bumps in the road. Choose to not let them rattle you.
Boston - CR7, CR6s, CR4s.
Thompson Adventures, Inc. -
Dang it! These sold already...for $20!!!! Rare albino Polks.
https://www.facebook.com/marketplace/item/2157635791472320
KEF Xq5s / Velodyne DD12 / Apollon Purifi 1ET6525SA / SST Thoebe II / Bluesound Node 130 / Oppo BDP-105D / Technics SP-15 w/SAEC WE-308SX & Ortofon AS-309 arms / Audio-Technica ART-1 & Dynavector XX2 Mk II carts -
SUPER DEAL OF THE DAY $1600 RUN, DON'T WALK
https://www.ebay.com/itm/227318962978?_skw=polk+sda&itmmeta=01KQCH91JF4C434B4JBNBVCS0E&hash=item34ed441b22:g:Af4AAeSwpZhp53n1&itmprp=enc:AQALAAAA0GfYFPkwiKCW4ZNSs2u11xDGXBl19Eu4DJtozvTwXDua65XhhlP50VASpZ1rNemrqFAC+qdCVsedmmF7dNMGd9i4Ua0ta0uU0SBxDtVRUt/qpVSSWMHE253TZe06je8srhdl7lYkM7ByvEHmaNnAshW5bNXJj5MdWkq5fKS/woHeGr24nP7oWrYK7BeLDAJoJNPP4O0LeGuTFIdTXiT1sIDjh46nifTG2ScC49PJ0yh2WgklJNe/k2K3h5WjCahsXpoI4dlx+/3R7PRrPiyzxXw=|tkp:Bk9SR6iZpJG7Zw
BAHAHAHAHAHAHA
Talk about upgrading to an IEC! Someone got confused! Little wonder the fuses are missing!
That one gets The Goat!
That's the uber-rare pin-blade-blade model.
The early first SDA 1's had a plug type interconnect socket. The middle area showing fuses are only placeholders for extra fuses. The fuses in service in-line are held in place under the black caps screws. The owner may have decided the use the receptacle as the original interconnect pins may have broken off. It could possibly work. Let me know if I'm wrong. -
Just saw this on FB! -
Re cap those bad boys and play em! LOL!!
WOW!!!!!
I would never touch those. -
WOW!!!!!
I thought maybe it was your first attempt at a Van Halen speaker.
Krylon's new color, Acid Trip Red.Don't take experimental gene therapies from known eugenicists.
LOL!!!
Looks more like a Biological Male wanting to compete in Woman's Sports.. -
aprazer402 wrote: »
Those may be unique SL3000's with back chambers. They'd be worth getting to install 198 diaphragms in. JAT.Don't take experimental gene therapies from known eugenicists. -
May have been done by a tasteless University of Alabama football fan.
I once had a residential client with strange textured, dark red paint on her den walls. When I asked, she said it was called "Elephant Blood." She was a rabid Bama fan.
Polk Monitor 5A Speakers Vintage $100
Listed 2 weeks ago in Mableton, GA
One woofer needs repair or replacement due to magnet shift (see images) else ok. Tweeters and passive radiators in excellent operating condition.
https://www.facebook.com/marketplace/item/1547624893498276/?ref=browse_tab&referral_code=marketplace_general&referral_story_type=general_listing&tracking={"qid":"-6754865143736168004","mf_story_key":"7191277105182554378","top_level_post_id":"7191277105182554378","commerce_rank_obj":"{\"target_id\":7191277105182554378,\"target_type\":6,\"primary_position\":95,\"ranking_signature\":2774880536801909716,\"ranking_region\":null,\"ranking_request_id\":8464235823542573300,\"commerce_channel\":501,\"value\":1.6743003480026e-5,\"upsell_type\":129,\"candidate_retrieval_source_map\":{\"26962229230055004\":3547,\"27174390148867352\":626,\"36006726588973383\":3001},\"delivery_flow_path\":null,\"grouping_info\":null,\"is_prefetch\":false,\"request_fetch_reason\":null}"}"Sometimes you have to look to the past to understand where you are going in the future"Harry / Marietta GA -
These are in my "neck o the woods". By the way @BlueBirdMusic. I have had no trouble at all with the belts you sent me! In fact, one of the T.T. I bought for now resides in Costa Rica with that goat you see in the picture above. Sent it as a gift to a great friend there and that is his goat! Thought about going to get those but I really do not need another set!!
