New to me SRS 2s
13»
    F1nut Posts: 52,296
    One of the worst performing amps I've heard had a damping factor of 1000.
  • SeleniumFalcon
    The ideal motion of a woofer's cone would be to move outward exactly as driven by the positive part of the electrical signal, then stop precisely when the positive portion of the electrical signal reaches its peak. Then it would begin returning to the rest position when the positive and negative portion of the signal is null and then begin the inward portion of its movement corresponding to the negative part of the signal. However, since the woofer cone has mass it is influenced by inertia, it wants to continue moving outward past the peak of the signal both during the forward and rearward part of its journey.
    One of the ways to reduce this overhang effect is to short out the woofer's voice coil between the musical signal. If a quick moving wire could be placed between the woofer's terminals exactly when the driving audio signal were at the zero point the woofer would tend to not overdrive itself. The next time you have a woofer outside of the cabinet and crossover gently push on the woofer's cone. Then take an alligator clip lead and place it across the woofer's terminals. Again push on the cone and you will find it a bit stiffer to move since the shorted voice coil causes a braking action against the coil in the woofer's magnetic field. Think of it as magnetic braking. There are some speakers that are shipped with shorting wires across the terminals to prevent excessive cone movement.
    Well, this is exactly what the amplifier's low impedance does, it acts as a short whenever there is no audio signal being produced. The woofer thinks it's being shorted out whenever there isn't a positive or negative audio signal for it to respond to. As to how much of this braking action is sufficient to minimize overhang in a woofer depends upon lots of variables. How much does the woofer's cone weigh? What is the voice coil and permanent magnet's relationship to the electromotive force propelling it? What about the surround structure, how will it effect the cone's movement? Is the enclosure sealed or vented? Is there a passive radiator also moving? What is the air-speed of an unladen swallow?
    xschop Posts: 5,739
    edited November 2025
    Is this why a 6502's lower midrange sounds better than a 6511's when substituted in the SDA slot?
    EDIT: great read while eating a turkey sandwich.
  • skipshot12
    skipshot12 Posts: 2,126
    Hegel, Benchmark....?
    Jesse,
    You should hear these overhauled Phase Linear amps after being WOPL'd... what's your favorite beverage for my demo?
    What's left of the original is the case, trans, meters and heatsinks.
    The specs after WOPL'd are incredible and the sound is well, I'd put it up against most amps.
  • Striker2237
    Striker2237 Posts: 128
    2 channel: MXN10, Anthem MRX740, Anthem MCA5, SDA1c recap/RDO, JL Fathom F112V2, Tributaries series 8A, Tara labs RSC
    Theater: Above plus Paradigm reference studio 100, Polk FX300i
    Projects: SRS1.2TL, SRS 2, M5Jr+
    Party/1st floor: iPad, Marantz SR5005, Paradigm reference S100v2, monster bulk cable
    B&O H9 Gen3
    xschop Posts: 5,739
    Like the spikes. Stachybotrys, not so much.
  • Striker2237
    Bunch of pictures from the SRS2 build, we are getting them finished this week.
    I think we managed to repair the MW155, the plan used was a bunch of the recommended craft glue and a very long/thin curved neck bottle normally used to dispense oil/vinegar/whatever at hibachi cooktops.
    That allowed us to reach the entire perimeter of the foam cone and re-glue it to the surround, it was left on a quad stack of towels to leave pressure on the whole stack with about 2 lb on top of the washer bolt via a socket to distribute the load evenly.
    I forgot to take a picture of that step but end result is passable, the compliance of the overall PR isn't perfect/it doesn't move quite as freely as the other one but I don't really have another option right now.
    Every driver had dynamatt added, magnets were glued, all the normal mods etc etc...
    The VR3 crossovers are in the SRS2s and I should be getting the commander series set for the 1.2TLs shortly.
    B&O H9 Gen3
  • Striker2237
    xschop wrote: »
    Funny enough it's just paint on that one panel, I also thought it was mold at first but someone just over sprayed badly at the factory!
    B&O H9 Gen3
    xschop Posts: 5,739
    xschop wrote: »
    Good deal. Sure looks exactly like the propagation pattern of S. Chartarum. I like the bracing in those too.
  • Striker2237
    xschop wrote: »
    xschop wrote: »
    I thought the same thing when I opened these, even it is mold it's been locked in there since 1980 and I did check to see if it flakes etc. Really seems like paint to me....
    The bracing is nice, I agree with that but man it took a lot of time and powergrab to get all the seams lined!
    B&O H9 Gen3
    xschop Posts: 5,739
    xschop wrote: »
    xschop wrote: »
    Im skiddish and would have to Kilz the interior lol. Looking good. Now you need a set of these to match those spikes...
  • Striker2237
    xschop wrote: »
    xschop wrote: »
    xschop wrote: »
    I may need a set indeed, do they come in black?
    B&O H9 Gen3
    pitdogg2 Posts: 27,767
    They do if you have them anodized.
    xschop Posts: 5,739
    I like flat black Rustoleum.
  • Striker2237
    Got the upgrade hardware for the 1.2s in, I'll be starting a thread for them/the build out. Also finally got my friends M10s upgrade finished
    B&O H9 Gen3
    VR3 Posts: 29,697
    Looking fresh!
  • Striker2237
    VR3 wrote: »
    Looking fresh!
    You would know haha!
    I'm running the SRS2s in 1 hour btw, hopefully they sound good!
    B&O H9 Gen3
  • bcwsrt
    bcwsrt Posts: 2,643
    xschop wrote: »
    Nooooooo! They are too good for that!
    Brian
  • Striker2237
    Night and day step up over my Sonicap/mills 1Cs!
    B&O H9 Gen3
  • Gardenstater
    Gardenstater Posts: 4,881
    And probably the inductors are higher quality than what Polk used.....perfect lay?......better copper?....
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
