Schematic for the RT-105
islandkid
Can anyone out there help me find a schematic for a China made Polk RT-105? Would like to upgrade caps. These speakers came with an old Onkyo compact system.
Answers
If it was a simple 2-way bookshelf, the crossover is probably very simple. It might only have one capacitor and one inductor. Just take them apart and see what is there. Post photos of the crossover if you can.See profile for rigs. Nothing else here.
The crossover is mounted to the binding post plate. Remove it and the crossover will come out with it. You won't need a schematic as the crossover will be very simple with the values printed on the components, likely one cap, one resistor and an inductor. You should upgrade the resistor while you are at it.
