What rear model surround speakers?
Hamboneian
Hello all you wonderful people. Thank you for your time and advice. Excited to be a part of the community. Ok so hear we go.. I want to do a 5.1 or a 7.1
Here’s the list of what I have to work with. So any ideas or suggestions in setting this up right would be greatly appreciated. Would love to know how you would set this up with what I have to work with and suggestions for upgrades are welcome too.
Here’s the list
Yamaha RX-V795a
2- xt70 towers (main)
2-lsi7 (Main or rears)
I- lsim70c (center)
B&w sub
So my question is ..what’s the placement of what I have right ? Or not? Also Whatca think about
getting some Fxi A6 for my rears ..
found some for 150.00
worth the additional expense? Also can I mix all the different type of models like LSI, Xt, and adding the fxi a6 or is there a comparison model for those rears you suggest?
Whatca think? Thank you all for your help .. really appreciate it ..
Here’s the list
Yamaha RX-V795a
I- lsim70c (center)
B&w sub
Answers
Welcome to Club Polk!
What are your room dimensions and furnishings?
Do you have a
- display (eg TV or projector)?
- DVD or Blu ray player?
You need to replace your AVR w/one that has HDMI connectivity if you plan to enjoy BluRay or 4K media. I could not “google up” specs for your AVR. The rear panel images didn’t show any HDMI connections indicating it is obsolete. In its favor are RCA outputs that allow connectivity to external power amps for all 5 channels - a worthwhile feature on your AVR shopping list.
Hold off on those Fxi a6 speakers as your current AVR has connections for only 5 channels.
Others will eventually chime in w/opinions.
PM pending
TonySamsung 60" QN65Q7FAMFXZA QLED, Outlaw Audio 976 Pre/Pro, Samsung BDP, Amazon Firestick, Phillips CD Changer
*all connected w/Premiere ICs
4 dedicated 20A feeds; APC H15; 5 Furman Miniport 20s -
I think “lsim70c” is missing a character. (eg Lsim703C) Please verify your center channel speaker model nomenclature. Google does NOT produce any images of the same⬆️.
PM sentSamsung 60" QN65Q7FAMFXZA QLED, Outlaw Audio 976 Pre/Pro, Samsung BDP, Amazon Firestick, Phillips CD Changer
You’ve actually got the foundation of a very solid system already. I’d run the XT70s as mains, the LSiM 706c center, and use the LSi7s as surrounds they’re honestly too good to waste as rears only. The FXi A6s can work well for a more diffuse surround field in movies, but timbre-wise the LSi7s are the better match, and consistency across the front/surround stage usually matters more than people realize.
Smells like AIPolitical Correctness'.........defined
