5JR crossover upgrades and questions
    xschop Posts: 5,838
    I'll be getting back a set of 5Jr's I built way back with the tweeter directly above MW, but closer than factory. I'll have a listen, since the bezel there is recessed a touch deeper with a curved profile. It also will glue in so there are no extra fasteners on the edge and the planes are machined perfectly flat when mated.
    I will be getting back the 5Jr crossovers and the 5B crossovers that he was running in them. The 5B X-overs seemed smoother or not as out front as the 5Jr's in them from what I remember.
    xschop Posts: 5,838
    Hadve these on the bench tonight installing binding posts and forgot that the phase of the tweeter is reversed on these...
  • VSAT88
    VSAT88 Posts: 1,383
    edited April 24
    Maybe some pics will help. This is a Baby Advent point to point job I did.
    And the best way to do it if you asked me.... You know for some odd reason I just do not like the crossover components hanging sideways off the back of the binding post cup. I really like that Monitor 7 point to point crossover you did there F1. Those crossovers look great. All of them. Very nice and "to the point", lol.
  • VSAT88
    VSAT88 Posts: 1,383
    GO ROB!!!!
