Replacement woofer for S15 bookshelf speakers
bryanj25
Hello! I have a pair of Polk Signature Elite S15 speakers, and the woofer on one of them is blown. I've removed the woofer from the cabinet to get the part number (which is RD9534-1), but I can't seem to find the part anywhere online, and Polk phone support wasn't much help. Would the woofer from the newer version of these speakers (ES15) work as a replacement? It doesn't have to be a perfect match acoustically. Thank you!
Answers
It appears the woofers are interchangeable.
If the voice coil is blown, I'll pay for shipping if you send it my way.Don't take experimental gene therapies from known eugenicists.
