R2R dac vs. Delta Sigma type dac
1235»
  • Conradicles
    Conradicles Posts: 6,379
    Any updates H9?
    I reread this thread and there is a lot of good information.
    heiney9 Posts: 25,514
    edited April 7
    I am in a holding pattern. They originally said end of April after the next production run. I'll be reaching out shortly to see where they are at on unit allocation.
    I've just been messing around with a few new pre-amp options in the office rig waiting for the new dac. Finally have the "right" combination of discrete op-amps in my trusty Keces HA-171 pre/headphone amp. What a killer neutral and dead silent pre-amp. Had to ditch all the Bursons as the combination wasn't right. Now I'm running (3) New Class D Ultimate Edition II.
    This one of the newly acquired pieces.
    Xduoo TA20 Plus
    Tube rectified, pair of 12AU7, class A buffer, metal film output caps, Elna Silmic II input caps, Panasonic filter caps, 24 step ladder resistor volume pot.
    It works great as a small footprint pre-amp for my Pass ACA's. I have 1965 Mullard GZ34 rectifier and a pair of 1953 RCA JRC 5814 3 mica black plates in her now. So sweet and the sound stage is HUGE.
    The Keces HA-171 w/discrete op-amps has more drive, but it can't match the sweetness and sound stage width and especially depth of the TA20 plus with the GZ34 and RCA 5814's.
    Just waiting and waiting for the DAC.
    VR3 Posts: 29,553
    Delta sigma dacs sound like musical wallpaper 😁, in reference to the 2d to 3d comment
    audioluvr Posts: 5,989
    I love my musical wallpaper!
    VR3 wrote: »
    Have to agree to disagree. Not sure where my 3D depth and width of sound stage is coming from then, certainly not out my ****. My main rig Supreme dac is heavily modded with discrete op-amps and expensive capacitors. Office rig dac is a previous version of the main rig dac and modded with discrete op-amps.
    There's a large amount of latitude in designs of DS dac's so to link them all together and poo poo them ALL is kind of short sighted.
    I'm definitely open to exploring r2r dac's. I've heard one GD Audio back 15 years ago, sounded like the music was in a paper bag. But that's just one, more budget unit, 15 years ago.
    I hope we can agree the design around the chip set is more important than the chip set. I'm sure there are wallpaper sounding r2r dac's (with regards to 2D and 3D).
    Also should compare apples to apples. Not fair to compare a $5K r2r dac to a $1700 ds dac and then say r2r is always better (not saying you did/are) just putting that out as a general comment.
    If I like the FiiO, I will explore a more spendy r2r to try in the main rig.
    VR3 Posts: 29,553
    I'm sure there's exceptions and system synergy etc that come into play. 😁
    I've been doing so much experimenting the past 6 months with the office rig. I've bought (4) Pass ACA amps - 2 separate versions. Can't take my ears off the 2nd version. Very similar to a First Watt F5 just a bit less oomph which will change when I build the 2nd one to go parallel mono.
    For awhile I put my Aleph 30 in the office rig. I want to keep it, A) it's overkill even though it really makes the R200's shine, it really, really does. B) it's to big for a desktop rig C) I should use the $$$ from the sale to recoup some of what I've spent. :D
    I've bought 6 different headphone/pre-amps (2) being Pass diy units, (3) being various Schiit models and the newest being a well, built, well designed CHi-fi piece, Xduoo TA20plus. (5) of the six having tubes. The 6th being the Pass diy ACP+ headphone/pre-amp.
    I've swapped 3 sets of speaker cables, bought numerous Russian tubes, and 6SN7 tubes for the above units. The other Pass diy pre is the Korg Nu-tube, which sounds great, but I'm going to replace some caps in the signal path and I ordered an LPS for it.
    I modded a Keces HA-171 heaphone/pre-amp I've bought a couple years ago. Put in discrete DEXA New Class D Ultimate II ed. discrete op-amps (not class D) they run in 100% class A.
    I have accumulated a lot of gear and until I play it all again with the R2R dac, I can't sell anything....lol.
    Pieces that are staying for sure are all the Pass diy pieces, Keces HA-171, probably the Schiit Valhalla 2 - OTL unit, I;ve got some really stellar Russian tubes for it.
  • invalid
    invalid Posts: 1,530
    Some Delta Sigma dacs don't even use chips, some use FPGA, one small manufacturer is even using 8 dual triodes and a BFT to do upsampling and filtering.
    treitz3 Posts: 20,122
    Going from two higher end DS DAC's to a mid-line dedicated R2R DAC for me was no contest. The R2R smoked both of the DS DACS's and the two, compared in the same system with no other change, wasn't even a fair comparison in my book. It was akin to having a race between a Yugo and a Bugatti.
    I now utilize 2 R2R DAC's in the rig and will never own another DS DAC again. Just my 2 cents on the subject.
    The first word that came out of my mouth when I first heard the R2R DAC was a very enthusiastic, "WOW".
    FWIW.
    I am all for exploring r2r dac's. I just try not to talk in absolutes, that was my only point. I'm a bit antsy to get it here. At first I wasn't at all concerned about the wait, but now I'm getting anxious.
    I am tempering my expectations as I'm not expecting it to be a world beater in the r2r segment, but it seems this will give a good "starting" point. The office rig is a quasi near field rig and it plays nuances quite well, so I should be able to get the flavor compared to my current favorite DS unit.
    One variable are the tubes. I have (2) sets to swap. A quad of 1963 Amperex BB lg halo 6DJ8's and a quad of 1972 Voshkod 6N23P gray shield, single post getter, red tips. I'll audition both after I break in the JJ's that come with the unit. Which ever tubes I prefer, will be a "set it and forget it" scenario.
