SDA CRS or CRS+
So I went a did a thing yesterday. These speakers were orphaned and I decided to give them a new home. Drove a little over 2 hours to pick them up. And as a bonus got to spend the day with my son. As the title says I'm not sure if they are SDA CRS or the CRS+. Need to get an interconnect cable or thinking about making one like in this thread.
https://forum.polkaudio.com/discussion/202082/sda-crs-crossover-recap/p2
Would like to find the ends that @DeRod used on page 2. If that will work for me. Planning on running them as they are for the time being and then figure out rebuilding the caps and possibly replacing the tweeters. Also thinking about making a set of stands like the factory ones but would need to find the measurements first. zzbf47p7legv.jpg
    xschop Posts: 5,677
    I vote CRS+.
    Nice score.
    pitdogg2 Posts: 27,630
    Check the drivers MW number to be sure.
    F1nut Posts: 52,188
    Pin/blade says CRS+.
  • Grabber70Mach
    Couple other pictures after looking at them this afternoon.
    F1nut Posts: 52,188
    CRS+
  • Grabber70Mach
    Grabber70Mach Posts: 73
    edited March 31
    Thanks for all the information so far. I'm glad to hear that they are the CRS+.
    For the interconnect cable, would it be better to:
    1. Purchase one from ebay
    2. DIY with cable like this: https://a.co/d/059c9RoO
    and use a male RCA end and disregarding the flat terminal.
    3. DIY with the same cable but utilizing the speakon ends and changing the female sockets on the speakers.
    Does anyone have a set of the original stands that they would take measurements of, I'd like to make a set.
    Toolfan66 Posts: 18,309
    If you're going to make your own, make better looking ones, and make them the full width of the speaker..
  • Grabber70Mach
    Toolfan66 wrote: »
    Yes that is the plan. What height should they be? Length of bottom foot? Appears to be 1" tube to me. Should I go with a thicker or thinner gauge of steel? I assume thicker would be better.
    billbillw Posts: 7,977
    If you're going to weld up a set, make sure to leave some holes to fill them up with dampening material like sand, aquarium gravel, etc. You could probably drill holes after and plug them up with a panel hole plug.
  • VSAT88
    VSAT88 Posts: 1,373
    To answer your question. the original stands are 25" tall. 14.5 wide. Just measured mine. Depth on top is 7" bottom is 13". Not that you need that if you are building your own I do not guess...
  • Grabber70Mach
    edited April 1
    Thank you @VSAT88. I am going to build my own and appreciate you taking the time to get the measurements. I'm sure I'll make them the full width of the cabinets like @Toolfan66 suggested, but the height and depth is what I wanted to know. This will allow me to make sure that they are stable. Thanks again.
    F1nut Posts: 52,188
    You should make the stands tall enough to have the tweeters at ear height. I found them too short and added tall spikes to increase the height. Still shorter than I would have liked.
    Also, the speaker should be isolated from the stand by resting on rubber pads or the like.
    This is exactly what I did.
  • HzTweaker
    HzTweaker Posts: 1,082
    2ch rig: Speakers: Magnepan LRS w/Magna Riser stands Preamplifier: Parasound P5 DAC: Fiio K13 Amplifier: Parasound A23 CDP: Pioneer DV-563A Cables: Wireworld Equinox 7 XLR ICs, Wireworld Ultraviolet 7 USB, AudioQuest Q2s, AudioQuest NRG X(preamp)
  • HzTweaker
    No problem. I'm looking forward to see what you come up with. :)
  • Grabber70Mach
    Would this be a decent amplifier to run these speakers: Integra Stereo Power Amplifier - Model ADM-2.1
    F1nut Posts: 52,188
    No
    edited April 3
    I'd say if you already have that amp, it will work, but it won't be the best match for the CRS+. I certainly wouldn't buy one unless it was less than $20. We probably need some more information on how you plan to set these up. What is your source/Preamp? How big is the room? How loud do you listen typically?
    Post edited by billbillw on
  • bcwsrt
    bcwsrt Posts: 2,600
    Oh, boy. Good thing we’re not dealing with @velvetfog here.
    Brian
    I don't think the warm and fuzzy lover is here anymore. The thread got deleted.
  • Grabber70Mach
    billbillw wrote: »
    No I'm looking to purchase a used amplifier on a budget. This is a new setup I'll be putting in my living room, the room is about 14x15. I don't really listen too loud but occasionally will turn it up a bit. I do have a Reisong-Boyuurange-EL-34 that I could possibly use.
  • Grabber70Mach
    edited April 3
    Another option I found that's close to me. A Rotel RB-1070 or a Adcom GFA-555.
    The Rotel should power those well.
  • Grabber70Mach
    billbillw wrote: »
    Was hoping to pick it up today but so far no response from the seller.
    Don't underestimate those little speakers. Polks thrive on good quality high current, it's not all about watts.
    F1nut Posts: 52,188
    edited April 4
    I'm no fan of Rotel amps. Ridiculous damping factor ratings means tons of negative feedback, which means it doesn't sound good.
    The Adcom 555 should also have good amounts of power, but beware that at their age, it may need some refreshing of worn capacitors or other parts.
    Also, F1 nut probably won't agree that anything other than Musical Fidelity is worth your time :D
  • dromunds
    dromunds Posts: 10,161
    I am also a big fan of Musical Fidelity amps
