Old audio rack. Found a purpose.
halen
Different stage in life. Have lots of other tools. Looking into better management.
How are ya'll doing it?
It speaks VOLUMES that you plug your chargers into a Monster power center. I bet it really helps the "harmonics" in those power tool batteries
I like it. One of my old racks sits in the basement and is chock full of kitchen knick knacks which my wife likes but me not so much. But it is better than filling it with vintage gear that will never get fixed.
I only have a few drivers on one top shelf of a 10" deep bookcase, and the charger is an arm's length away on a hanging 3.5"d x 12"w x 3' tall shelving unit I made for VHS tapes years
ago. There's a rolling metal grate shelving unit under it that has my extension cords (rolled up on round cord holders on the bottom shelf. The top is a catch all tool shelf of pliers, chisels and little pry bars.
My set-up has been like that for YEARS.
This shelf looks like it would work.
https://www.amazon.com/Spampur-Organizer-Organizers-Organization-Cordless/dp/B0B3DL2V5D/ref=asc_df_B0B3DL2V5D?
Here's an even bigger unit that would hold your tools.
https://www.walmart.com/ip/Power-Tool-Organizer-Wall-Mount-Heavy-Duty-Drill-Holder-Garage-Storage-Suitable-Rack-Room-Workshop-Garage-Utility-Storage-Cordless-4-Tier/5080310803?
