XSchop's modded 5jr
124»
    xschop Posts: 5,382
    edited February 2016
    First off, apologies to you as I referred to you as Polksda in a few previous comments. I need more coffee.
    On page 2 of the glue pic, It is most important that the glue completely surrounds old woofer, tweet, and port hole. The bridge between woofer and tweeter is rock solid on the previous set now as I checked with a screwdriver on the re-foam process. The edges alone would hold the plate with no issue as this glue is mega strong.
    That said, I am taking your advice and removing the old woofer instep/base on this set as I know that the bridge will still be rock solid.
    xschop Posts: 5,382
    Another mod previously not posted....
    My Bosche right angle with 90° countersink I machined the shank to fit, c2uvdss7xygo.jpg
    worked a charm at fluting the inside port. Smoothed it off with 220 sandpaper by hand.
    Post edited by xschop on
    xschop Posts: 5,382
    Last but not least, on this second billet plate set, I opened the ports up another 0.025" to 1.150 Diameter.
    Reason being, the best tool to open up the factory port hole is a longer serrated-edge hole saw using the faceplate as a guide. Serrated edges are not accurate however. My new plates have a show quality finish that I don't want scarred when re-drilling the port.....
    xschop Posts: 5,382
    New Caps and resistors showed up. I'll start X-over mod tonight. Belt sanded the edges smooth with factory baffle and removed MW instep. I had to get new fine-tooth blades for my jig-saw. This MDF will chip easy if you use a coarse blade.....
  • Looks like fun !
    I still have an extra pair of 5 Jr's that are a little more scratched up than my good pair and I'm thinking of changing out the stock tweeters for some 1962 Jensen horns that have lived in my closet for years.
    I'll have to make an adapter ring to cover the stock hole. as it's too wide, but I figure if it doesn't work out, I'll just keep the woofers and crossovers for spares.
    I just finished re-wiring the whole rig with pro cables and re-introduced my equalizer into the mix.
    xschop Posts: 5,382
    What diameter is each horn where it would slip thru box?
    The smaller diameter of the oval in the MDF is 2.85"
    The top-bottom width of the SL-1000 plate is 3.05"
    IMO this is a faux pas on Polk's behalf also.
  • The interior flange hole would be 2"x6 1/4" , but the plate itself would have to be 4"x 6 3/8".
    That would not only cover the original tweeter hole, but also the two grill snap holes, which would have to be removed anyway to accomodate the horn's flange.
    If I was running your machine, I'd just make a whole new face plate and countersink the horn's flange an 1/8" and do likewise with the woofers.
    (only another 1/8" for those)
    More than likely though, I'll just go down to Michaels and make a couple out of 1/8" plywood doll house stock, then break the edges and paint them black.
    xschop Posts: 5,382
    Ah OK. I thought you were talking about one of those small dia. Horn tweets that you just drill a hole to mount.
  • Nightfall
    Nightfall Posts: 10,083
    The only non "cheated" time aligned Polks are the RTA-12's
    afterburnt wrote: »
    Village Idiot of Club Polk
    xschop Posts: 5,382
    Nice and substantial, I take it you don't need -6° stands for those either?
    How would those compare to the 11T's?
    xschop Posts: 5,382
    Much easier and cleaner. I'm going to wrap them in foam this time.
    Does it matter if the resistors are physically touching capacitors?
    xschop Posts: 5,382
    Found my old thread thru Duckduckgo lol.
    I'll post my progress here on this side project. Got an old set of these back with a blown tweeter, gouged cabinet and slight dent on the woofer. They were set up in a game room near a pool table.
    Herculiner works better than Rustoleum for sure...
    xschop Posts: 5,382
    Soldered in new tweeter leads...
    xschop Posts: 5,382
    This one I carefully sanded around baffle edge and added water putty to area that particle board got gouged. Luckily no metal was nicked. Rest of it looks good.
    xschop Posts: 5,382
    Cabs are done. I'll have to throw the other one together in the morning and have a listen. Only spare plugged 6502 I have on hand has the 8 hole mod and a carbon fiber one....
    Wonder what Mr. Polk would say @ what I do to his classics...
    pitdogg2 Posts: 27,264
    Bless your heart🖤
    xschop Posts: 5,382
    Really could care less what anyone thinks. Best sounding vintage midrange from these. Just gotta dial in the highs. Looks like this tweeter just needs an extra 0.5 ohm on the circuit.
    F1nut Posts: 51,966
    I like the look of the aluminum bezel. How thick is it?
    xschop Posts: 5,382
    edited March 22
    All of them were 5/8" 6061-T6. Think I stated it before. The KSi of the alloy versus the particle board is a huge difference.
    Got a couple 2 ohm resistors to swap out later this evening. It's really hard to say if its even needed.
    Amazing the bass these put out too with the extra air space and port size.
    WAF factor is a hit too and I like I dont have to build stands...bonus
    I'll let the forum decide. Billet face CRS+ this go round?
