Home Audio vs. Car Audio Speaker Wire
KhanYu
KhanYu Posts: 1
1. What is the difference between home audio speaker wire and car audio speaker wire?
2. Is there any side effects or benefits from using car speaker wire?
Second Topic:
I was thinking of bi-wiring my rt800i with 10 or 12 gauge wire and terminate the receiver end with locking banana plugs.
1. Can anybody suggest a good brand of plugs that will not break the bank? Currently, I have seen WBT, IXOS, and ULTRALINK.
2. What technique of connection should I look for on the banana plug? Crimp and solder? Crimp solder with set screws? Compression? Quick Lock? Slug with Compression Screw? Compression Screw?
3. What gauge will the banana have to accept to fit two 10 or 12 gauge wires?
TIA.
  • goingganzo
    goingganzo Posts: 2,793
    edited May 2002
    car wire has more sheilding and thicker insolaton at least the stuff i use it is designed for temp changes and other things in a car not found in a house
  • jeberhart
    jeberhart Posts: 69
    edited May 2002
    I think car wire is supposed to be shielded so it eliminates or reduces the noise inherent in car systems, but since my car system still can sound pretty whiny/noisy/crackly to me sometimes, I suppose the **** really doesn't do what it's supposed to. What else is new?:mad:
  • sgtgto
    sgtgto Posts: 310
    edited May 2002
    Hi:
    There is really no difference between car and in home speaker wire other than how much room you have to route the wire in your car or home. You would want to match the ga. to the amount of power your amp or amps have, and the length of wire run. If you are picking up noise in your system it is usually not from the speaker wire but from the ignition bleeding through to the head unit. This can be stopped by a filter capacitor you can purchase at RS.
    I usually use a 16 or 18 ga. wire for my car, and 14 or 12 ga. for home. Using this as a reference buy what you can afford and like.
    Gary
  • jeberhart
    jeberhart Posts: 69
    edited May 2002
    Thanks, Gary; I'm going to do that.
  • RomaSk
    RomaSk Posts: 1
    The main difference between home audio speaker wire and car audio speaker wire is the environment they are designed for. Car audio wire is usually more flexible and built to handle heat, vibration, and tighter installation spaces inside vehicles, while home audio wire is meant for stable indoor environments. Electrically, there is no real sound quality difference as long as the wire is pure copper and the correct gauge is used. Using car speaker wire for home audio will not cause any side effects; in fact, the higher strand count can sometimes make it easier to work with, although the insulation color may not look as clean in a home setup.
    For bi-wiring the RT800i with 10 or 12 gauge wire, that is a solid choice and should work well. You do not need extremely expensive banana plugs; brands like Sewell, Monoprice, or Mediabridge offer reliable options without spending a lot. The most practical connection type is a set-screw or compression style banana plug because it provides a secure connection and is easy to install without soldering. Most banana plugs comfortably accept 12-gauge wire, while 10-gauge may depend on the plug design. If you plan to insert two wires into one plug, it may be tight, so using separate plugs or stepping down to 12-gauge for bi-wiring is usually the easiest solution.
    pitdogg2 Posts: 27,914
    OP hasn't been here in over 20yrs, very doubtful your answer goes anywhere to anyone, not to mention they probably haven't had the speakers in a very long time.
