RTA12C CROSSOVER DISSASEMBLY
how does one release this? am i missing something? when i press the little wedge inwards and lift up on the crossover board , it wont budge. is there a certain side i start on or something maybe?
2CH - RTA 12C, Monoprice M2100X, SMSL-D1SE2 DAC, AudioQuest Cinnamon USB Cable, Streaming Via PC Tidal
  • Unknown
    edited March 13
  • HzTweaker
    HzTweaker Posts: 1,136
    What's up with the crossover, are you repairing it or doing an upgrade?
    2ch rig: Speakers: LSi9s with VR3's Fortress mods Preamplifier: Parasound P5 DAC: Fiio K13 Amplifier: Parasound A23 CDP: Pioneer DV-563A Cables: Wireworld Equinox 7 XLR ICs, Wireworld Ultraviolet 7 USB, AudioQuest Q2s, AudioQuest NRG X(preamp)
    Standby: Magnepan LRS w/Magna Riser stands
  • camjules
    camjules Posts: 6
    edited March 13
    I am going to refresh the caps/resistors/polyswitch, pretty much just trying to return it to factory performance.
    I went with Jantzen electrolitic caps , poly caps, and resistors because it was cheap, I know others change all to poly caps but I didn't want the difference in poly vs electrolitic esr values affecting the tonal quality of the speaker.
    I also ordered some RDO194 tweeters.
  • HzTweaker
    Word, why not change the polyswitch with a .5 omh resistor?
    F1nut Posts: 52,406
    camjules wrote: »
    Got news for ya, the tonal quality will change regardless.
    xschop Posts: 5,897
    Agree with F1 (it happens)
    That tonal quality of an electrolytic cap vs same value film cap is technically called 'distortion'.
  • camjules
    camjules Posts: 6
    edited March 14
    I expect tonal quality to change, and wonder if it will be an improvement vs what it currently sounds like to my ears
    Not sure how to reply to posts lol sorry guys im new to this.
  • camjules
    camjules Posts: 6
    Yes I agree..... although, ESR or as you say "distortion" becomes part of crossover tuneing process, it was my intention to try and get as close as possible to the original sound polk was trying to capture, with the RTA 12C.
    After all, I was born in 1990, and didnt get to hear them in 1985😅
  • camjules
    camjules Posts: 6
    I went back and forth on the .5 resistor idea, after reading the forums here on polk.
    however, the originak polyswitch used was RXE135 @ .3 ohms, and it was important for me to stick with identical values.
  • Unknown
    edited March 14
    xschop Posts: 5,897
    camjules wrote: »
    They were not optimal in 1985 due to Polk budget/business and using electrolytics.
    Not knocking you, but a set of cheap Solen/Dayton caps will give better resolution than the electrolytics.
    I tried a few different caps on my 5B tweeter network, and Nichicon FG 12uf wasn't as detailed as the Dayton.
  • camjules
    camjules Posts: 6
    I would like a much better sounding speaker, carrying on with my bad self has been a life long journey.
    I didnt mean to offend, I'm open to your ideas, and that the information i have to give can be wrong or misguided.
    xschop Posts: 5,897
    Don't think anyone's offended. It's a forum, and suggestions are just that.
