Silver Coil Dome - How ID Model & Remove from Wall
Hello,
I purchased a residence built in the mid-1990's that has Polk Audio built-in wall speaker pairs in 6 rooms with 12AWG 4-channel cables running to a stereo cabinet in which the components have been removed. [There is also a second in-tact stereo system in another cabinet, which has 4 of the same speakers hard wired that works well.]
I want to replace the removed stereo components, but I would first like to remove the 12 speakers to confirm the precise models, ohms specs, and wire color coding to each pair. The 12-4 cable from each room's speaker pairs into the control room have these 4 colors: Red-darker, Red-lighter, white and tan. I have identified the rooms for each 12-4 cable, but the 4 individual wires are not labeled. Any guesses how the L+, L-, R+, R- wiring sequence would typically be done with this cable color coding?
Using the manual for the similar appearing current RC55i speakers, I was able to remove the grill, which revealed this marking: “Polk Audio Silver Coil Dome”, which I understand is consistent with the mid-1990's. The size of this speaker frame is 7”W x 16.5”H. Can anyone identify the precise model from this info? Is there a manual available for Silver Coil Dome speakers?
The RC55i manual, which did not address how to remove an installed speaker, says on page 8 to loosen the rotating wall clamps, turn them inwards and tighten to rotate the clamps behind the drywall. So I loosened the 8 screws that are around the edge inside the frame. I could hear what sounded like most of the clamps rotating down, but the speaker appears to be stuck at a couple of points. I am not sure if turning the screws too many turns will let the clips drop into the wall, so I stopped to get some advice from those who know this model. Any tips, thoughts or suggestions on how to remove these speaker? Is there a photo of the rear of this type of speaker available?
Thanks for any advice.
Answers
