Monitor, signature, or in wall?
BeRad
BeRad Posts: 745
Well,I have a blown driver in my fxi A4 that apparently isn't available, so I'm going to have to decide on some new surrounds.
RTI a9 and csi4 in the front.
I'm considering ending up with a 7.1.4 system with the surrounds and rears running off the avr to start.
Surrounds will be wall mounted in a 20' wide room. If I end up with 7.1, rear wall is about 5 feet behind mlp.
I'll be able to properly aim in-wall or wall mounted as I will be modifying the walls anyway.
Any thoughts from those with experience?
    VR3 Posts: 29,763
    They probsbly pop up cheap on ebay
    billbillw Posts: 8,371
    Yeah, buy used from FB Marketplace or similar. I see A4 and A3 pop up all the time. Really any of the RT or RTi series will match well enough for rear surround purposes. BTW, the In-wall Polks that I've seen have a a directional design to them so they point inward somewhat.
  • BeRad
    BeRad Posts: 745
    The problem with eBay is cross border shipping is going to be an extra 50 to 100 bucks.
    What border? Just find sellers from your side.
  • BeRad
    BeRad Posts: 745
    I was lucky enough to find a replacement driver so I can fix the fxi a4.
    For rears I have rc85i that I could use. Think that would work well or would 65-RT be better for the matching with the rest of the RTI line speakers I have?
