REL S850 Subwoofers
Not a fan of them either.
Well, let me tell you something folks, I am completely in awe, I can tell you the grills wouldn’t keep me away from these bad boys, they say about 100 hour break in, well, break in or not, these are some very detailed subwoofers.
They are really bringing out the best in the music.
This right here is incredible !!!!
Told you!
I’m here when I can offer additional advice. 😄2 Channel Rosso Fiorentino Volterra II, 2 REL Carbon Limited, Norma Revo IPA-140B, Norma Revo DAC-2, Lumin U2 Mini, VPI Prime w/SoundSmith Zephyr MIMC, Modwright PH 150, Denon DP-59l w/Denon DL-301MKII, WAY Silver 3 Ana+ Speaker Cables, WAY Interconnect Cables, AudioQuest Niagara 7000 w/Dragon, WAY power cables for all other sources. -
The main thing with break-in is the subwoofers start to play a bit louder over the first month or so. That's remedied by adjusting the volume controls a couple notches. I had to adjust mine a couple times.
Beautiful subs...the grill choice is puzzling. Anyone know why REL chose them?
Appears you can get a black cloth grill if desired.
https://www.bestbuy.com/product/rel-carbon-special-black-label-grille-cloth-black-cloth/J3R85VSPFGPost edited by F1nut atPolitical Correctness'.........defined
