Monitor 5
Grabber70Mach
Grabber70Mach Posts: 38
edited March 3 in Speakers
Hello, first post here. I'm trying to determine the series of a set of Polk Monitor 5 that I picked80n1gdraqn0n.jpg
up. They don't have a fuse in the back. Thanks for your help. 73dyy1fqze5b.jpg
«13
  • Gardenstater
    Gardenstater Posts: 4,803
    5B. The earliest 5B still had the fuse but they soon got rid of that and went with the polyswitch that you have.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • Thank you for the identification. I'm thinking about rebuilding the crossovers. Is it better to rebuild the original ones or would it be alright to purchase these and rebuild them then just swap them out?rnjt4upqxl5m.jpg
    pitdogg2 Posts: 27,276
    So does it make sense to buy another crossover to just rebuild with better caps? Seems like a waste of good dollars that could be better spent on quality caps and resistors.
  • Gardenstater
    I purchased a spare pair of crossovers so I could take my time and still play my speakers. I prefer that 2nd configuration of PCB to the one you have. If you got that one I'd upgrade it instead of the one you currently have.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • @Gardenstater Thank you for iding them.
    @pitdogg2 Thanks. While I see what you're saying they aren't really that expensive.
    @Gardenstater Thanks that's was my plan and thought process if I purchased them.
    xschop Posts: 5,390
    edited March 6
    Nice set of 5Bs.
    Your 2nd upgrade should be the tweeters.
  • Grabber70Mach
    edited March 6
    So I did get the crossovers I posted above to rebuild just waiting for them to arrive. @xschop Thanks I had been thinking about the tweeters, what would be a better replacement RDO-194 or 198 would be a replacement for the 2000's? If I decided to get the tweeters would I have to change anything in the crossovers? Also trying to determine which capacitors and resistors to get, I'm looking for an upgrade but middle ground that doesn't break the bank. Recommended vendor or vendors. I've seen mills resistors mentioned as well as Clarity and Dayton capacitors. Thanks.
    xschop Posts: 5,390
    I dropped in 12uf and 5.6 Clarity PX for the tweeter network with metal plates and 198's originally. I just used Daytons on the MWs (think 33uf on suggestion from WMG for budget at the time)
    Mills 10w coil wound resistors.
    Do butyl mat the MWs and PRs at a minimum.
  • I believe that the RDO-194 is a direct swap for the 2000's? If that's correct and the RDO-198's require modification. I believe I'd prefer to use the 194's. I should receive the crossovers I ordered today and will verify the components values. Then compile a list of components to order. Also will look at getting some butyl mat for the MW's and PR's. Since I'm going into the cabinets is there anything else I should consider doing or replacing?
  • Also is there a tutorial on gluing th magnets? I've looked but somehow probably missed it.
    Yes.
    Yes.
    edited March 9
    That certainly shows you the proper place to apply the glue. I'd use JB weld two part epoxy. Popcicle or craft sticks are your friend. It is a long tedious, messy job, take your time and you'll be fine.
    https://www.jbweld.com/product/j-b-weld-professional-size
    F1nut Posts: 51,970
    RD0(ZERO)194-1
    xschop Posts: 5,390
    I'd suggest a 7/8"- 1" round dowel front to back between MW and PR. Along with hurricane nuts, you'll get the best midbass out of them. The cabs are particle board and front baffle could use stiffening.
  • Gardenstater
    edited March 10
    We don't want to forget the backwave/standing wave absorption behind the midwoofer. I did a 6" x 6" square of Blackhole5 in my 7Bs. If I had to do it again I would try NoRez that doesn't have the floating layer of vinyl with layer of closed cell underneath. Reason being what if Danny Ritchie is correct that BH5 can mass load the cone. Also, I would orient it diagonally to the enclosure, although you'd have to notch out for the dowel mentioned above.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • Grabber70Mach
    edited March 10
  • Grabber70Mach
    edited March 10
    I'm trying to picture this and having trouble with it. Are you saying you would put it behind the mw from say the front right side if your looking at it from the front, to the back left side. Thanks
  • xschop wrote: »
    I'm assuming the dowel would need to be attached through the front and back of the box. I'll look into getting some 8-32 hurricane nuts. Thanks
  • Gardenstater
    edited March 10
    I'm just saying that instead of the way I oriented it here, I would rotate it 45 deg, so that the points face up and down and right and left. Note mine is missing a corner not on purpose but because I was limited by the material a forum member donated to me. You will have to decide what you think works best for you in the M5. In the 7B I would've done two dowels because the baffle is wider and they would clear the corners of the BH5/No Rez just fine with the diagonal orientation. I don't know where the XO plate on the back is located in the M5.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • Grabber70Mach
    edited March 10
    I received the crossovers that I plan on rebuilding yesterday.
    I can make out the values on the resistor and two capacitors. But the small yellow device, maybe capacitor? I cannot really make out what its value is. m9dc98yruv06.jpg
  • Gardenstater
    edited March 10
    That's the "polyswitch" that you will want to replace with an appropriate sized resistor of the same quality as the other ones you may be replacing. Polk went with polyswitches instead of fuses at some point, to protect the tweeter. They get more and more troublesome the more times they have been tripped. Everyone does away with them when they upgrade XO but you have to adjust for their resistance. Different value reistors have been used by different people and I don't really know what the best value is. DarqueKnight did a thread on this.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • I'm going by this schematic, I believe it is the correct one.
  • Gardenstater
    Initial trip resistance 0.5 to 0.77 Ohms. One hour post trip resistance 1.17 Ohms. Those are the specs. I think at some point Polk started pre-tripping them. Maybe you want 1 Ohms to replace it. Others will advise.
    https://mm.digikey.com/Volume0/opasdata/d220001/medias/docus/1000/RXE050.pdf
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
    edited March 10
    The resistance of the polyswitch is a half ohm, we all used .5ohm 10 or 12 watt vishay-mills resistor in place of the polyswitch.
    F1nut Posts: 51,970
    THIS
    xschop Posts: 5,390
    edited March 10
    If you're going with 194's, I'd just jumper the polyswitch until you get a good listening session on them.
    If you install billet RDO plates later on the 194's you may want to add the 0.5 ohms. JAT
    The dowel, to be straight front to back, will need to be offset right between 11 & 12 o'clock above PR because of Xover cutout.
    My 5Bs are modded this way also.
  • I'm assuming that I can just put a jumper in place of the polyswitch and use a 2.5 ohm resistor in place of the 2 ohm resistor. Here is a list of what I plan on ordering for the crossovers. Is this correct? Has anyone dealt with this company before? Thanks.4e2c5mnusioj.jpg
