REL S850 Subwoofers
Toolfan66
REL makes the best subs I have yet heard in my rig.the high-level connection makes them easy to dial in for two channel, and if you use the wireless connection, I found no loss of performance.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
I have an S/812 and the S/850 is the updated model to that. It's a bit better in terms of amp power and drivers.
Two are better than one.
These are primarily designed to blend with music rather than thump. -
Updated new model with a hefty price jump. I have a S/812 being used in a combo HT / 2 channel system & excells in both. Very easy to integrate using the hi-level connection.
Depending on your budget I would not hesitate to go with a used S/812 & put the savings into a second one. However you would be very, very happy with the new model S/850. You can't go wrong with a REL. -
The new S/550 will be comparable in performance to the older S/812. The new S/850 is comparable to the previous Carbon Special model.
My choice, if I was in the market for newer, would be a pair of the S/550 in a medium sized room with most speakers or a pair of S/850 only in a large room with large speakers.
Recommend asking Rel customer service what the best option is. They don't tend to oversell. -
I have 2 Carbons and have been very happy with them. Buy a pair of the best your budget will allow…Buy a pair of Carbons and never look back!2 Channel Rosso Fiorentino Volterra II, 2 REL Carbon Limited, Norma Revo IPA-140B, Norma Revo DAC-2, Lumin U2 Mini, VPI Prime w/SoundSmith Zephyr MIMC, Modwright PH 150, Denon DP-59l w/Denon DL-301MKII, WAY Silver 3 Ana+ Speaker Cables, WAY Interconnect Cables, AudioQuest Niagara 7000 w/Dragon, WAY power cables for all other sources.
Buy a pair of whatever you get. Or at least plan for 1 now and another soon haha.
A pair of the new Carbon Special Black Labels would come in under $10K...
...by $2
https://rel.net/products/carbon-special-black-label?variant=50827079811288 -
There was a nice pair of S850 for sale here locally, for a good price, probably should have jumped on them. I have never had my ears on REL Subs..
Although the S series have a separate LFE input and can be put in a corner for home theater duty, they're really designed to shine when their speaker level inputs are used and they're co-located close to each main speaker for a musical system.
Rel also makes home theater specific room rattler subwoofers like the HT/1510 Predator but I think SVS has better for the money for that purpose.
In my case both systems I have Rel subwoofers in have sound where the subwoofers aren't even noticeable after they're dialed in and once the ears get used to them. If the subwoofers are turned off though the system sounds thin and weak up through the midrange even!
They can also be set up stacked in a four or six sub array, but I think that's only for the obsessive audiophile.
If the Rel subwoofers would be for the big SDA models I wouldn't go lower than the S/850 or previous S/812.
That's a great feature of REL subs, being able to run simultaneously in both 2 channel & HT.
I'm running 2 REL's a single S812 (both hi-level & LFE hookups) used for both 2 channel & HT & a single HT1205 MKII only for HT. When running HT the S812 & HT1205 are both active & the room is rocking.
Now switching over to 2 channel the HT 1205 is not active (only LFE hookup). The S812 is awesome using the hi-level hookup for 2 channel. The S812 is calibrated separately for both venues. -
I would have put these with my SDA’s, and moved my SVS’s to the HT rig.
Got to admit the line array with 6 subs look awesome!! -
Remember this thread… it is not often we find universal agreement and praise of a product line.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
Remind us...is it fine to run these subs with SDAs and the dreadnought?
Absolutely… just need to use one for each speaker. The high level connects to the amp outputs not to the speakersThe Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
I've seen some connect at the speaker end so just asking. Thanks!
I don’t see why that couldn’t work as well.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
Conradicles wrote: »I've seen some connect at the speaker end so just asking. Thanks!
Yes that's another option for hook up.
I'm just going to pile on and say that I'm very happy with my REL T/9X. Wish I had space for two of them.SystemLuxman L-590AXII Integrated Amplifier|KEF Reference 1 Loudspeakers|PS Audio Directream Jr|Sansui TU-9900 Tuner|TEAC A-6100 RtR|REL T/9X SE Sub
Well, since we are talkin’ Serie Ts, even my baby T/5xs impress me every day.
Brian -
Purdy for sure
You just ordered 6 of them, didn't you
Child's play...I'm running a 12 pack! Lol! -
Better be worth it, I just man handled my SVS SB1600’s to the basement.. 😬
I don't know if I should laugh or send you some bag balm ....
Not sure if I’m a fan of the wood grills’ they are built very well, just not sure if I like the look.
The wood grills don’t appeal to me. Even mine with the black grills were only used the first few days. The grills have since been in the original boxes in the attic.2 Channel Rosso Fiorentino Volterra II, 2 REL Carbon Limited, Norma Revo IPA-140B, Norma Revo DAC-2, Lumin U2 Mini, VPI Prime w/SoundSmith Zephyr MIMC, Modwright PH 150, Denon DP-59l w/Denon DL-301MKII, WAY Silver 3 Ana+ Speaker Cables, WAY Interconnect Cables, AudioQuest Niagara 7000 w/Dragon, WAY power cables for all other sources.
Had to see what y'all are talking about...YUCK!Political Correctness'.........defined
President of Club Polk -
They might look okay in a 1980s courtroom.
