Cheap parts in the L600 speakers?
muncybob
So I was surfing around in YouTube yesterday not looking for anything in particular and saw some videos of L600 reviews. Saw one from GR Research in which there was high praise for the speaker followed by it could have been so much better with different caps, resistors, etc. Doing a quick search here I see GR is no stranger to many of you and there are varied opinions on GR's work/comments.
If their statements are true that while the L600 is a good speaker but built to a certain price point and modding the crossovers would make them a worthwhile exspense , I'm wondering if anybody has gone down this road with these speakers?
My L600s sound very good to me but as usual I've got that curiosity as to how much better could they sound?
Yep, my name really is Bob.
I've worked on a few l200 at this point and there is of course improvements to be made but to be fair Polks mission is to bring great sound to every living room and the legends perform.
Also given the complexity of the crossovers of these speakers is you really went all out you just about need to go external due to the size of the inductors if all air core.
The build I came up with targeting air core inductors at specific points takes up the entire bottom of the speaker and there's still 2 or 3 iron cores left.
Biggest difference is in the detailing and transparency of the entire speaker using quality parts but Polk would have had to charge maybe 2 to 3 times as much to include that stock.
The r200 with halfway decent parts was 1500 and that was still with sand cast resistors.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Par for course. Besides X-overs, given their stamped-steel baskets, they would also benefit from Dynamat at the very least.
Don't take experimental gene therapies from known eugenicists. -
I was thinking Dynamat too....but, I don;t hear any ringing and neither did the Gr guy in the video.Yep, my name really is Bob.
Parasound HCA1500A(indoor sound) and HCA1000(outdoor sound), Dynaco PAS4, Denon DP1200 w/Shure V15 Type V and Jico SAS stylus, Marantz UD7007, Polk L600, Rythmik L12 sub. -
Just because you don't hear any ringing doesn't mean it is not happening within the enclosure and translating back to the cone.
I'd also suggest foaming the inner frame of the midrange too.
Danny also did a review of an L800 a couple weeks ago. I think it's one of the few times I've seen him throw up his hands in defeat at not being able to upgrade them or even map out the complex crossovers. So many parts, so little time!
I suspect if Polk did design them with unusual for the industry parts quality the cabinets would have had to be bigger and the cost would have put them out of reach for most potential buyers.
https://www.youtube.com/watch?v=W2lJ0Wu1l2w
I listened until he said they were not high-end speakers.... Yes, he is right that it would be expensive to upgrade them, but to say they are not worth the trouble?The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
Listening to him talk about them shows he knows very very little about their design anyways
Edit, he admits as much in the video as well
Edit 2, also the fact he can't really listen to them only having one speaker, yet calls them a gimmick is very strange- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
I heard: "Don't buy this speaker, buy my kit." And I agree. Polk has never been a truly high end speaker, but where this description falls flat on it's a** is the price point. Sure most wealthy audiophiles would consider Polk as not Hi-Fi due to it's price but it's bang for buck has always been top tier. IMHO you have to spend a LOT more money to get to any next level.
As for his opinion of the SDA being a gimmick. Well his entire podcast is a gimmick so takes one to know one.Gustard X26 Pro DAC
ASR now has more credibility IMHO....The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
People still pay attention to him...LOLPolitical Correctness'.........defined
President of Club Polk -
Still... not as bad as an Infinity Kappa 9 crossover.
Make one yearn for the days of an SRS rebuild.Don't take experimental gene therapies from known eugenicists.
Well, based on the apprx. cost of parts & labor to rebuild both speaker crossovers approaching $1600+ I would be spending almost as much as I paid for them a few years ago and it's a crap shoot if these old ears could make it worthwhile. I think I will treat the baskets though,
Looking forward to some brave soul doing the mod and posting
This is great set of threads that discusses/tests and measures crossover components upgrades.
Anyone thinking about XO upgrades should read these: https://www.audiosciencereview.com/forum/index.php?threads/capacitor-upgrade-in-crossover-is-it-audible.12287/
The full mini series:
Capacitor upgrade in crossover - Is it audible?
Capacitor upgrade - part two
Capacitor upgrade - part three
Replace resistor by low-inductance resistor - Is it audible?
Different Binding Posts - is it audible?
Audible difference in high-end capacitors? - ABX samples
Trigger Alert!............3............2..............1.............
George / NJ
Onkyo A-8017 integrated
iFi nano iDSD DAC
iPurifier3
iDefender w/ iPower PS
Everything sounds the same!! Not even sure why there are so many choices- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Trust the science, when it's convenient.
I can say that Daytons make SL2000's sound 'better' lmaoDon't take experimental gene therapies from known eugenicists. -
Solens for everyone!
Yikes- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
zvucnik, here's some capacitor evaluations done the proper way by using what really matters, the human ear.
https://www.humblehomemadehifi.com/Cap.htmlPolitical Correctness'.........defined
I did a mod for @Clipdat... The pmc monitors. Stock had solens and we went to clarity cmr...
Night and day...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
I love this website. I use it all the time when researching caps in the signal path and for x-overs.
H9"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | Galion TS P75 Pre | Holo Audio Cyan 2 Dac | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul!
