Cheap tube integrateds
tonyb
Whats the forums take on thes cheap tube pieces from China ? Stuff from Dayton like the hca 200, Junsen, and a cast of others ? Gotta get more tubes back in the mess.
From what I gather, some people say they sound fairly good but the longevity factor is where your going to get hurt.
    mhardy6647 Posts: 35,562
    edited January 2
    The Dayton stuff is all (or at least virtually all) of the hybrid kind. The tubes do something, but it's not always clear what. The power amplfier are normal chip amps.
    There are "in betweeny" exceptions: Monoprice has or had an all vacuum tube integrated using PP EL84 outputs that at least once was cheap enough to be worthy of consideration.
    https://www.monoprice.com/product?p_id=27222&srsltid=AfmBOopi6-YXUUOgH29Q1IucZOjGUsO9Xa9H1t9gF6Z6vwaFpqGhi1AB
    Looks like it's NLA -- and the price at this link is double what they were originally. :(
    Parts quality, tube choice (often weird Chinese versions of Russian tubes, often difficult or impossible to cross over to US or European equivalents), and general weirdness are, IMO, all good reasons to avoid most if not all of them like the plague. :#
    Something like a restored Scott 222 family member -- or even something like this odd little kit-built Lafayette bare-bones PP 6BM8 integrated (with MM phono preamp), restored, would be a far, far better choice, IMO.
    On the other hand, a quad of new, matched (or even good, used) 6BM8 will set you back considerably more than the cost of the whole danged amplifier! :/
    Also: PP 6BM8 is good for about 8 watts per channel -- so there's that, too. :#
    I really like the Scott 222 family! They're not uncommon, they aren't as well known (nor as powerful) as the bigger Scott integrateds, and they sound great. Might find a good one for a reasonable price even nowadays.
    Someday I need to finish the rehab of my 222C... :blush:
    It's actually prettier than it looks in that photo; there is some grubby grime on the front panel, though... and note the Minnie Pearl price tag, too! B)
    edited January 4
    Thanks Mark, but those older tube integrated amps are not that cheap anymore. I hear ya on the Scott 222. But cheapest one by me was going for 600 with no work having been done to it. Unless you can find one with some work having already been done at a decent price, that cost can add up fast. Great sound, but will kill ya on the up keep as a daily driver. Scott 299's average a g note, same with Dynaco's. Scott has the sound I'm looking for though. Even their old receivers are going for a good buck these days.
    Saw a Cayin for sale by me for 400. Reviews are great with everything but rock music....which means bass shy or too rounded. A tube pre amplifier would work also, but pickens are scarce under a grand.
  • newbie308
    newbie308 Posts: 843
    Maybe something from Jolida? I don't know what your price range is.
    https://www.ebay.com/itm/168057566328
  • displayname
    displayname Posts: 1,248
    You could avoid the cheap Chinese stuff and get an affordable quality Italian made Class-A tube integrated from me. I just listed my Mastersound Duventi of Facebook. ;)
    Discogs
    There have certainly been some JoLida/Jolida/Black Ice products of good quality that would (still?) be good values today. That said, some serious judiciousness will be required when shopping for one... since there was lots of skulduggery between two companies that, for a time, both claimed to be the real "Jolida". :(
    SCompRacer Posts: 9,399
    edited January 5
    Scotts have a nice sweet sound IMO! Just a thought about older tube gear. I'm guessing a Scott 2xx or other tube gear of that era might be reactive to modern voltages we have today. Like the Scott 340 ('62-'63) and 399 ('59-'60, pre FM stereo) that I refurbed for Ed. They were designed at 115/117 line. Line voltage at our house can be 125VAC at times. Power transformer output increased at 125vac so tube heater and plate voltages exceeded max levels which would shorten tube life.
    Two choices. One could increase resistance on all circuits affected at max line voltage. I opted for choice 2. I assembled a switchable bucking transformer to reduce line voltage. It displayed line in and out. Voltage choices were line out with two stages of reduction. The transformer selected had an amp rating to support both the 335 FM multiplexer and 399 receiver, like 4 or 5 amp IIRC.
    Scott knew FM stereo broadcast was near, so they built a FM multiplexer for the 399. Prior to stereo, the 399 was designed for simulcast. One channel on AM, the other on FM. The 399 sent the FM signal to the 335 multiplexer which returned R and L channels back to receiver.
    Above pic set to phono. It sported magic eye tubes for tuning. The input switch had an AM/FM and AM/FM MX Stereo setting.
    Beautiful Scott pieces Rich.
    Yeah Jolida is a possibility. I'm going to wait and see what turns up
    Still using a Grant Fidelity tubedac 11. Anyone have any insights to the best tube to use? Think i have a Sylvania in there now.
  • Unknown
    edited January 6
  • Unknown
    A few pre amps came up by my for 500 and below.
    Front runner has to be the Eastern Electric Avant, stock tubes for 550.
    Vincent audio Sa31, stock tubes, for 300.
    Acurus da100 , though SS, is about 300 also, but may be a tad bright on the upper end for me. The Vincent from what I read, needs to be sent back for a tube change if one so desires as they are soldered in.
  • maxward
    maxward Posts: 1,742
    I have not heard that Eastern Electric preamp, but based on how my M520 integrated sounds, that’s definitely your front-runner. @heiney9 has some experience with EE stuff.
    heiney9 Posts: 25,710
    Get the Avant, killer price. Killer pre-amp. I answered your PM. The only draw back for the Avant is the extra expense in getting some great tubes. There are (8) in all. It can be a bit expensive and then you have to subdue the urge to want to roll.
    I think for you Tony, you probably aren't all that interested in rolling. I can point you in the right direction for a NOS tube combo that is set it and forget it.
    FYI the Acurus is on the bright side and it's very long in the tooth. My brother had one years ago for his office rig. It did it's job. I would be afraid with this older gear that caps are going to start failing and if they haven't completely failed they may not be 100%
    Some Avant ****
