Budget ultrasonic vinyl cleaning
Upstatemax
I needed an ultrasonic cleaner for cleaning brass casings, for reloading. I decided to keep it reasonable and while kicking around the Vevor website, I came across this:
https://www.vevor.com/ultrasonic-cleaner-c_11064/6l-ultrasonic-vinyl-record-cleaner-cleaning-machine-complete-w-drying-rack-p_010265133877?adp=gmc&utm_source=google&utm_medium=cpc&utm_id=23093382192&ad_group=189722589027&ad_id=778133999269&utm_term=&gad_source=1&gad_campaignid=23093382192&gbraid=0AAAAACq8bLVhdLwZFk1VsOJGBev78HBsr&gclid=CjwKCAiA3L_JBhAlEiwAlcWO54l7DwsrEJn27vCAyRE6xyp1-eEvXrLeyQCwxBAKItezcJcEIbBzFRoCkR4QAvD_BwE
I figured for the $15'ish it added to the "standard" version, why the heck not try it.
For it's base purpose, it's fantastic at cleaning up brass!
After a good clean out, I set up the vinyl cleaning setup.
I need to research some better solutions for the ultrasonic, but I have a good bit of the "Spin Clean" solution kicking around, and a quick search claims it works alright.
So, I dropped in 4 caps of the solution and started a cleaning cycle.
I set the water temp to 39*c (about 102*f) and ran 6 albums for 15 minutes.
I picked a few albums that I've retired for being too noisy, such as ZZ Top "First Album" and Ray Charles " Ray's Moods".
The cleaner didn't perform any miracles, it's not going to repair surface damage, but it did clean up the sound of these 2 by a really good margin. Way less hiss, crackles and pops. To the point that I'll happily put them back into rotation.
I also put my MoFi copy of "Brothers and Sisters" in. This album has always had a frustrating amount of noise to it, especially for what MoFi albums cost.
All I can say at this point, the noise is GONE.
So, it seems I'll be cleaning my entire collection of vinyl on this machine!
Thankfully it's a relatively small collection.
That is awesome.
If the record is already clean, I just use a surfactant.
Triton X-100 (10 drops per run) and distilled water.Speakers: Polk Lsim, ATC SCM19 v2, NHT SuperzeroSpeaker Cables: DH Labs, Transparent, Wireworld, Canare, Monster: Beer budget, Bose ears -
That is awesome.
Awesome.
Thanks for the suggestion!
I'll pick some X-100 up and get to some more cleaning! -
Way cool.
I have had the same experience. I thought it was just me trying to convince myself the records sounded better but when my wife said they sounded better after spinning one of her favorites (Hall & Oates Abandoned Luncheonette) I knew I was going to spend a fair amount of time cleaning all the records.
I even clean brand new records to be sure no crap is in the grooves from the pressing and the quate(sp) in my fluid helps eliminate the "clicks" esp in this indoor dry winter air.Yep, my name really is Bob.
Parasound HCA1500A(indoor sound) and HCA1000(outdoor sound), Dynaco PAS4, Denon DP1200 w/Shure V15 Type V and Jico SAS stylus, Marantz UD7007, Polk L600, Rythmik L12 sub. -
I also like to clean brand new records. For me, I knew the Spin Clean wasn't doing a great job. Did it provide an improvement?
Sure, but it always seemed to leave a lot of surface noise making me think the records could still be a lot cleaner.
Glad I decided to give this a go. It was a really inexpensive way of providing a really good improvement. -
What do you think of the version with the retro knobs instead of the digital look, less money.Amplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156 -
I decided on the one with digital look as it seems to have a better setup for the actual record cleaner. Can clean more records at once and has more adjustability. -
If cleaning more than 1 record at a time be sure to leave enough space between them for proper sonic cleaning.Yep, my name really is Bob.
This one does come with spacers that go between each record, they also cover the labels to help keep them better protected.
I would not put 7 on at one time not enough space between records. I plan on putting on no more than 3 at a time and spacing them out.Amplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156 -
I use these label savers with O rings on my ultrasonic so the labels don't get wet. I got them on ebay, from China of course. With six of these I do three LP at a time. I can put the records away right after cleaning, distilled rinse and vacuuming on the VPI 16.5. I use TergiKleen, a concentrated Tergitol based fluid.
Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
@SCompRacer do you have a link to those spacers?Amplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156 -
I thought I got them from ebay but turns out it was Amazon. The ones Wewu Rounds sell on Amazon now appear to have a rubber seal around the perimeter. Might try ebay for LP label savers and see what you come up with. I don't recall paying 20 bucks each for three back in 2022.
I'll have to measure the spacers provided from Vevor, once I get home.
They looked to be about 1/2" to possibly 3/4".
Probably wouldn't be too difficult to add some form of rubber ring to them, to seal out water. But the batches I ran, none of the labels got wet. -
I always seemed to get the edges of labels wet, like it wicked in-between the plastic spacers and records while rotating in the ultrasonic bath. I need to consult @mhardy6647 to learn if the Tergitol mix (S-3 and S-9) I previously used made my distilled water wetter.
This guy has some ideas to make the cleaner more effective.
https://www.youtube.com/watch?v=f3t9lGj1Iqw Amplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156 -
Thanks for the video!
Has some good info to think about.
The adjustable power supply looks like a really good idea. -
I got one of these to slow down the rotation and clean one album at a time for 15 minutes as recommended by one reviewer.
https://www.amazon.com/dp/B0BKPZZV83?ref=ppx_yo2ov_dt_b_fed_asin_titleAmplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156 -
Just curious if anyone has tried a spray-on surfactant then used compressed air to clean?Don't take experimental gene therapies from known eugenicists.
No experience with sonic cleaning of records. Have always wanted to try one.
Have done the scrub and vacuuming via machines. They always do a good job other than having to deal with the static they build. -
I don't have a large record collection, so I had cleaned them all with a Spin Clean.
They looked very clean to me until I used the Vevor, take a look.
Puritan PSM156 -
Puritan PSM156 -
^That came off your record?
Nice to see that's not getting pounded into your grooves. -
Groovy micro-abrasions man.Don't take experimental gene therapies from known eugenicists.
@skipshot12 it came from the grooves as the spin clean had the outside spotless.Amplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156
