Reisong A10 EL34 Hi-Fi Audio Stereo Tube Amplifier
Irrenhaus
Irrenhaus Posts: 1,102
Hi,
Got this one during Christmas, I know it is not the greatest but sounds good, but it drives the Linton nice at a bit more than half the volume. I was using the Cambbridge as the source and that is using dual volume knobs which is not great, but I think the Cambridge has a fix output setting, I need to find it. But all sounds good to my ears.
Cheers
HTAVR-Pioneer SC99XPA-DR3 Differential Reference AmpPolk R-700Rear- RT150Side- RT150Center-CSi5Sub-Rythmik audio F25Player- Panasonic DP-UB9000Projector- Optoma CinemaX P2Screen- Silver Ticket Products STR Series 6 120"Audio Room 2ch rig.Cary AE-3, Onkyo M-504, Marantz SA8005, Azur 851NWharfedale - Linton, SVS SB12-NSDMinis Forum PC (streamer) and Panamax MX5105Headphone rig;Schiit JOTUNHEIM and different headphones.Samsung 42" flat screen TV.
  • halo71
    halo71 Posts: 4,632
    That poor M504 looks a lil beat up. Did you do the LED conversion?
    --Gary--
    mhardy6647 Posts: 35,029
    Single-ended EL34 outputs in that amplifier?
    Are they wired as triodes or natively as pentodes?
    If the latter, does it use single-ended ultralinear output topology?
