1937 Philco Radios
skrol
skrol Posts: 3,448
edited December 2025 in Electronics
I have inherrited my grandparent's old Philco 37-650 from 1937. It has sat for many years unused. My aunt passed away in August, the house is being emptied to sell and I couldn't see this radio going to waste. It was dirty as he-double-toothpick and I was amazed how it cleaned up with vacuuming and some very dilute mild dishsoap. The cabinet need a little work and I'm hoping I can bend Jesse's ear for some advice.
I am not sure if it works yet and am refraining from trying to power it up without a dim-bulb tester. I have also read that the caps should be replaced before even trying.
I am also inherriting my dad's old Philco 37-60, also from 1937. He has had this since he was a young man in Fells Point, dabbling in electronics. He restored it a number of years ago. Before he passed away in November (tough year), he told me that it still works.
Unfortunately, my dad gave away his Hickok tube tester and caddy of tubes :( .
Stan
Main 2ch:
HT:
Other stuff:
    EndersShadow Posts: 17,704
    I think Jesse made some recommendations in my thread about my tube stereo console as to how to clean those. I’d go check it out.
    From https://forum.polkaudio.com/discussion/177816/today-i-stole-me-a-piece-of-gear/p1
  • skrol
    skrol Posts: 3,448
    Thank you. It sounds like I started ok. I rather like the idea of not refinishing the cabinet. There is a patina to what is there. I am wondering how to clean off the decades Pledge furnature polish that was likely used?
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • It's very important to determine if the radio has a "hot" chassis:
  • skipshot12
    skipshot12 Posts: 1,953
    My wife has a hot chassis.
    Oh...
    Those are some cool radios.
    They used to make some really nice stuff with great care and craftsmanship.
    skrol wrote: »
    The touching up was specific to my cabinet as it had a couple small scratches.
    F1nut Posts: 51,749
    skrol wrote: »
    The only product that will successfully remove the silicone infused Pledge crap
    is a dewaxer/silicone remover solvent such as this, https://www.genesisautobodysupply.com/product/2835/etalon-degreaser-silicon-remover-1-liter-etantisil-1?srsltid=AfmBOoqd-0dxeEPQY4YYGlzul4dX1n1Tw-y8ndFM35szGIizVTRb3U3AMfg
    As for touch up and I see a lot of those areas use Mohawk touch up markers. The trick is to apply the marker and immediately wipe the excess with a soft cotton cloth to leave the marker color in the scratch not around it. Use a marker color that is a bit lighter than the actual color.
    Forgot to mention, when all cleaned up and touched up, etc. apply Renaissance wax to restore the luster.
  • skrol
    skrol Posts: 3,448
    Wow, thanks for the info on hot chassis and on the cabinet touch-up. This is good stuff.
    Will the degreaser attack the finish? Also, any suggestions how to fix the top finish.
    Also, I guess my grandfather was not very technically inclined but I suppose this worked as an antenna. Either that or he booby-trapped the nut cracker to keep us out of his wallnuts and almonds.
    Stan
    Main 2ch:
    HT:
    Other stuff:
    F1nut Posts: 51,749
    It will not affect the finish.
    There is nothing you can do about the finish on the top. The finish has delaminated.
  • skrol
    skrol Posts: 3,448
    edited January 2
    I had read about using vinegar and water first and moving to something stronger (i.e. mineral spirits) if that doesn't work. Should I skip the vinegar / water and go right to what you mentioned above?
    I realize this thread has deviated from the electronics and onto cabinet restoration. Perhaps I should take further discussion to the DIY or Clubhouse.
    Post edited by skrol on
    Stan
    Main 2ch:
    HT:
    Other stuff:
    F1nut Posts: 51,749
    Use the product I suggested.
  • bcwsrt
    bcwsrt Posts: 2,407
    I know you're talking about the cleaning and prep stage at the moment, but don't forget the mention of Renaissance wax in F1's edited response above. That stuff is (expletive) amazing!
    I have to assume the solvent he recommends is equally excellent.
    Brian
  • skrol
    skrol Posts: 3,448
    Thanks, I'll give it a try. I seem to be inherritng multiple vintage pieces that could benefit from cleaning away the years of build-up.
    Stan
    Main 2ch:
    HT:
    Other stuff:
