Speaker Jumpers
mantis
mantis Posts: 17,556
edited December 2025 in DIY, Mods & Tweaks
What's up everyone,
So Lets talk about speaker factory jumpers. Most people throw them right in the trash and use speaker wire terminated in Spade or Banana jacks right? Hardly no one is buying I wiring or bi amping there speakers, maybe some but mostly not.
Ok so if the jumpers are copper built with a gold plating , what is the actual difference with the jumpers compared to the speaker cable and spade or banana jacks? Have anyone thought about this? Think about IF your banana jack or spade connector is built from gold plate copper what is the actual difference here?
Is it a visual thing? I can see if the jumpers are built out of lesser quality material like tin or brass , makes sense to replace them with something better but if the manufacturer made them out of copper and plated them with gold to protect them, then what are you actually gaining?
I never thought about this up until now. I always just did what everyone else usually does , throw those jumpers in the box or trash and replace with a custom built or bought jumper.
Dan
  • Emlyn
    Emlyn Posts: 4,797
    I use biwired speaker cables with speakers that have two sets of binding posts to avoid the jumper issue altogether. At least that's what I say. B)
    I've always thought it a gimmick to have two sets of binding posts on run of the mill home speakers. They're not needed in almost all cases.
    Toolfan66 Posts: 18,140
    Emlyn wrote: »
    Same, I have biwired speaker cables in my 2 channel set-up, my HT I just leave the jumpers, because I don’t care there..🤣
    VR3 Posts: 29,518
    Most played jumpers from the factory are gold plated brass, not copper
    VR3 Posts: 29,518
    Also biwire cables are just really long jumpers, just saying
    billbillw Posts: 7,727
    VR3 wrote: »
    Depends how they were made...I made a custom DIY set of bi-wire shotgun cables with Nanotec Golden Strada and I essentially made them with a built in jumpers that were soldered together inside of the first pair of spades.
    Not the best aesthetically, but they sound great. I used this set with my SS-M9 for about 10 years. I went with something different when I brought the Revels home.
    VR3 Posts: 29,518
    Eh maybe if there's different wire top and bottom maybe... Maybe. It all goes thru a few inches of whatever is in the amp.
    I am a firm believer in quality cables but cables have Very large level of diminishing returns.
  • Emlyn
    Emlyn Posts: 4,797
    I had a couple pairs of the old PS Audio Statement speaker cables (bought cheap!) that had the different metal composition for the top and bottom. I remember they were kind of rich and smooth sounding, definitely not neutral, but that's what I needed back then with bright RTi series speakers. They turned out to be way too inflexible for long term use.
  • mantis
    VR3 wrote: »
    I replaced my jumpers on my new speakers and I didn't hear any differences at all. I put them back in and still no change sonically. I guess because it's such a short distance that electrically with the surface contact of the jumpers , there isn't any sonic improvements to be had. Not to mention they are gold plated, I have no idea the quality , materials used but it doesn't seem to help or hurt when they are in or out replaced with copper 14g wire. I even did bare wire to remove the connectors and still no difference I can hear.
    Dan
  • tratliff
    tratliff Posts: 1,806
    edited January 1
    mantis wrote: »
    VR3 wrote: »
    I agree a set of jumpers is not going to make a drastic improvement. But even a slight improvement can compound as they are made.
    This is a very common item discussed in Facebook groups. Some seem to hear a difference, others can not. The naysayers generally get buutt hurt when questions are asked about the system and quality of the setup.
    Tell us about the system you tried this on. Speakers/amp/receiver/source/cables?
  • mantis
    tratliff wrote: »
    mantis wrote: »
    VR3 wrote: »
    Ok,
    The system is as follows
    Monitor Audio Bronze 50 7g Speakers
    Sunfire HRS8 Subwoofer
    Audioquest HD6 Subwoofer custom built
    Parasound A52+ amp
    Tried also
    Niles SI125 amp
    Also
    Sonos AMP
    Audioquest 14-2 Slip Speaker cables connected bare wire, Banana and tried Audioquest spades.
    Sonos Connect and Bluesound Node Sources.
    I've been fooling around with these new Bookshelf speakers I have.
    Dan
  • skipshot12
    skipshot12 Posts: 2,087
    Kept the original jumpers on my SDA SRS's. Just cleaned the contact points really well.
    skipshot12 wrote: »
    I would toss those, and make new ones..
    F1nut Posts: 51,912
    ^THIS^
  • Emlyn
    Emlyn Posts: 4,797
    And consider changing the binding posts for a better type than the original too. B)
  • gp4jesus
    gp4jesus Posts: 2,019
    Emlyn wrote: »
    And consider changing the binding posts* for a better type than the original too. B)
    *Make and model?
    The factory “jumpers” can net just two connection points versus 3 or more. OTOH I like Billbillw’s idea very much in his pic above
    *all connected w/Premiere ICs
  • Emlyn
    Emlyn Posts: 4,797
    Cardas or WBT are popular binding post upgrades on this forum and come in a wide range of prices. There are other brands that others have used as well. They may or may not have an audible effect depending on the system but they do tend to be able to provide a more secure connection for high quality speaker cables. The originals were only really designed for standard speaker wires that were used by most people back when the original SDA speakers were new.
    F1nut Posts: 51,912
    Shameless plug...I've got some really nice WBT binding posts listed here.
    SCompRacer Posts: 9,121
    At first I used Harmonic Technology Pro-9+ on the low and HT Pro-11+ on the high. I had them from the active xover bi-amped InnerSound ESL days. Then I sold the 11+ and put the Salk supplied Cardas jumper on.
    My Harmonic Technology Pro-9+ are internal bi-wire. I considered making them bi-wire but HT changed hands and supplied different connectors so they wouldn't match. That could affect resale value if I check out first and the wife has to sell them.
    Then I purchased some AudioQuest Jupiter's here and retired the Cardas jumpers.
  • skipshot12
    Toolfan66 wrote: »
    skipshot12 wrote: »
    ^Gonna have to try this^
    Any recommends?
