1937 Philco Radios
skrol
I have inherrited my grandparent's old Philco 37-650 from 1937. It has sat for many years unused. My aunt passed away in August, the house is being emptied to sell and I couldn't see this radio going to waste. It was dirty as he-double-toothpick and I was amazed how it cleaned up with vacuuming and some very dilute mild dishsoap. The cabinet need a little work and I'm hoping I can bend Jesse's ear for some advice.
I am not sure if it works yet and am refraining from trying to power it up without a dim-bulb tester. I have also read that the caps should be replaced before even trying.
I am also inherriting my dad's old Philco 37-60, also from 1937. He has had this since he was a young man in Fells Point, dabbling in electronics. He restored it a number of years ago. Before he passed away in November (tough year), he told me that it still works.
Unfortunately, my dad gave away his Hickok tube tester and caddy of tubes
Stan
Main 2ch:
HT:
Other stuff:
Main 2ch:
HT:
Other stuff:
So Cool!
I think Jesse made some recommendations in my thread about my tube stereo console as to how to clean those. I’d go check it out.
From https://forum.polkaudio.com/discussion/177816/today-i-stole-me-a-piece-of-gear/p1
"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
Thank you. It sounds like I started ok. I rather like the idea of not refinishing the cabinet. There is a patina to what is there. I am wondering how to clean off the decades Pledge furnature polish that was likely used?
Stan
Main 2ch:
HT:
Other stuff:
It's very important to determine if the radio has a "hot" chassis:
My wife has a hot chassis.
Oh...
Those are some cool radios.
They used to make some really nice stuff with great care and craftsmanship. -
The touching up was specific to my cabinet as it had a couple small scratches."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
The only product that will successfully remove the silicone infused Pledge crap
is a dewaxer/silicone remover solvent such as this, https://www.genesisautobodysupply.com/product/2835/etalon-degreaser-silicon-remover-1-liter-etantisil-1?srsltid=AfmBOoqd-0dxeEPQY4YYGlzul4dX1n1Tw-y8ndFM35szGIizVTRb3U3AMfg
As for touch up and I see a lot of those areas use Mohawk touch up markers. The trick is to apply the marker and immediately wipe the excess with a soft cotton cloth to leave the marker color in the scratch not around it. Use a marker color that is a bit lighter than the actual color.
Forgot to mention, when all cleaned up and touched up, etc. apply Renaissance wax to restore the luster.Political Correctness'.........defined
President of Club Polk -
Wow, thanks for the info on hot chassis and on the cabinet touch-up. This is good stuff.
Will the degreaser attack the finish? Also, any suggestions how to fix the top finish.
Also, I guess my grandfather was not very technically inclined but I suppose this worked as an antenna. Either that or he booby-trapped the nut cracker to keep us out of his wallnuts and almonds.
Stan
Main 2ch:
HT:
Other stuff:
It will not affect the finish.
There is nothing you can do about the finish on the top. The finish has delaminated.Political Correctness'.........defined
I had read about using vinegar and water first and moving to something stronger (i.e. mineral spirits) if that doesn't work. Should I skip the vinegar / water and go right to what you mentioned above?
I realize this thread has deviated from the electronics and onto cabinet restoration. Perhaps I should take further discussion to the DIY or Clubhouse.Post edited by skrol onStan
Main 2ch:
HT:
Other stuff:
Use the product I suggested.Political Correctness'.........defined
I know you're talking about the cleaning and prep stage at the moment, but don't forget the mention of Renaissance wax in F1's edited response above. That stuff is (expletive) amazing!
I have to assume the solvent he recommends is equally excellent.
Brian -
Thanks, I'll give it a try. I seem to be inherritng multiple vintage pieces that could benefit from cleaning away the years of build-up.Stan
Main 2ch:
HT:
Other stuff:
I ordered the degreaser silicone remover that you recommended from Genesis Auto Body Supply. I assume that Miracle Additive Clearcoat Enhancer is not the same stuff. It looks like they sent the wrong stuff.Stan
Main 2ch:
HT:
Other stuff:
Definitely the wrong stuff.Political Correctness'.........defined
I called. They are sending me the right stuff.Stan
Main 2ch:
HT:
Other stuff:
