BPT BP-2 switch replacement
bikerboy
bikerboy Posts: 1,247
edited December 2025 in DIY, Mods & Tweaks
Hi,
I bought this power conditioner many years ago on the forum when you could consider shipping a 70 lb box with a massive transformer. The power switch started to shut off by itself more and more regularly as of late. Even with nothing plugged into it the switch would trip. Google said the switch is a thermal circuit breaker. Luckily the part numbers were visible, ordered the part and $60 and a $5 tariff later part arrived. Soldered the new one in and back in business.
I've been copying vinyl to the pc for a few weeks since the weather has been bad lately. I thought I would use a different power conditioner while I wait for the switch to arrive. The recording levels showed more random noise that I hadn't noticed with the BP-2. So I didn't record any vinyl until I fixed the BP-2. Also noticed noise from the router so that's off when recording. Happy to have fixed the BP-2 so I don't have to think about a replacement. LP to pc sounds great using 24/192 wave files. Can't really hear the difference between LP or wave files.
Main system: Lyngdorf TDAI-2170 w Polk LSiM 703/ Pioneer 42" plasma w ONN Streamer, Sangean HDT-1X tuner
Vinyl: Nottingham Spacedeck->Pioneer PL L1000 linear arm->Soundsmith DL 103R w Contact line stylus->SUT->
Bottlehead Eros tube phono preamp
CD: DIY Shigaclone
    pitdogg2 Posts: 27,921
    Nice! 👍🏽👍🏽
    heiney9 Posts: 25,724
    Great work!
    xschop Posts: 5,931
    Good save. Does that shunt capacitor prevent popping/surge on start-up?
  • bikerboy
    It's a Varistor. I didn't want to replace it unless needed. The part number is visible and is 450v.
    CD: DIY Shigaclone
