BPT BP-2 switch replacement
bikerboy
Hi,
I bought this power conditioner many years ago on the forum when you could consider shipping a 70 lb box with a massive transformer. The power switch started to shut off by itself more and more regularly as of late. Even with nothing plugged into it the switch would trip. Google said the switch is a thermal circuit breaker. Luckily the part numbers were visible, ordered the part and $60 and a $5 tariff later part arrived. Soldered the new one in and back in business.
I've been copying vinyl to the pc for a few weeks since the weather has been bad lately. I thought I would use a different power conditioner while I wait for the switch to arrive. The recording levels showed more random noise that I hadn't noticed with the BP-2. So I didn't record any vinyl until I fixed the BP-2. Also noticed noise from the router so that's off when recording. Happy to have fixed the BP-2 so I don't have to think about a replacement. LP to pc sounds great using 24/192 wave files. Can't really hear the difference between LP or wave files.
Main system: Lyngdorf TDAI-2170 w Polk LSiM 703/ Pioneer 42" plasma w Flex Streamer, Sangaen HDT-1tuner
Bottlehead Eros
CD: DIY Shigaclone
Bottlehead Eros
CD: DIY Shigaclone
Nice! 👍🏽👍🏽
Great work!
H9"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | Galion TS P75 Pre | Holo Audio Cyan 2 Dac | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul! -
Good save. Does that shunt capacitor prevent popping/surge on start-up?Don't take experimental gene therapies from known eugenicists.
It's a Varistor. I didn't want to replace it unless needed. The part number is visible and is 450v.Main system: Lyngdorf TDAI-2170 w Polk LSiM 703/ Pioneer 42" plasma w Flex Streamer, Sangaen HDT-1tuner
Bottlehead Eros
CD: DIY Shigaclone
