CRS+ (2 board vs 1 board) questions.
Questions
- For anyone who had a 2-board crossover and upgraded to the last gen, what did you notice as the most palpable changes to the sound/presentation?
- Did anyone who went to the last gen crossover regret it?
- There’s no way to Dread a non-last-gen crossover, correct? If you want to do mono blocks (or just get that Dread improvement), you must go gen 4, right?
- There’s a size difference between the 2-board CRS+ and the 1-board, true?
- Has anyone built a last-gen CRS+ cab from scratch?
- Did anyone ever felt the entire face of a CRS?
Background
I got a pair of junkyard CRS+ to have my way with.
They were in rough shape; a fitting companion pair to my 1C ;)
I’ve sat with them for a month now. I’m impressed. They don’t have the force of the 1C, but wow. What an amazing little speaker.
Going through old posts to learn a little more about them, I came across a few things where people talked about the comparisons between SDA models, but not much on the last 2 CRS+ revisions.
The Thrifty Setups in Mah House Big thrifty stereo in the basement w/ my custom SDA-1C (built with help from kind forum members) * Beautiful 1966 MCM GE console upgraded w/ Bluetooth, Dual turntable, and Paradigm speakers in family room * Swanky 1980 Realistic system and great TEAC eq with dancing colored lights in the living room * custom 5B on a system for my Dad * Ye Olde college stereo in the garage
    pitdogg2 Posts: 27,312
    The big difference between them is the 2 board blade/Blade crossovers both blades carry signal. The 1 board pin/blade crossovers, only the pins carry signal, the blades connect to the ground inside the cabinet to the negative binding posts. Therefore you have the ability to use monobloc's or non-common ground amps only then does the blade come into play, with the use of the AI-1 cable or a dreadnought to tie the grounds together.
  • pitdogg2 wrote: »
    Ohhhhhhhh. O.k.
    I think I'd misunderstood the pin/blade vs blade/blade setup. I'll stare at schematics again later. Much appreciated!
    [thinks]
    I'm still floored with how wide an image these things throw.
    [listening now]
    I wonder how the difference in crossover design affects that.
    I believe I'd read a DK post where he preferred his TL'd last gen to other versions, but I don't recall seeing anyone tear apart the listening experience between the 2 crossovers.
    Toolfan66 Posts: 18,181
    edited December 2025
    Mine were originally CRS Dual Board, I upgraded them to single board CRS+ Fully Hot Rodded.
    I owned a set of fully hot rodded 1C’s as well many moons ago, I like the 1C’s but would never part with my CRS+’s for them..
    IMO The Monitor 7’s, CRS+’s, and the 2B’s (single board as well) are the three special Polk Speakers that will just about slay any room with the right upgrades and gear. It doesn’t have to be super high end gear, just good power.
    Let the magic happen.. 😎
    Don’t forget the Dreadnought..🤓
    I think the distance between the drivers on the CRS and SDA SRS 2 help create that huge soundstage. It's intoxicating 😉
    xschop Posts: 5,417
    Agree with Pitt. Stick a set of CRS X-overs and drivers in 10A/B cabinets, the same sound signature/tone emits with a narrower soundstage.
  • Toolfan66 wrote: »
    Aha! No regrets between the crossover styles?
    Did you do the 198 or keep them 194?
    I love my 1C. They're fantastic (whether stock or modded). But the soundstage width on the tiny CRS+ is borderline unbelievable.
    You'll need some new drivers to go from CRS to CRS+ as well as the crossovers.
  • - I've got the right mids from the second pair of 1C I bought for the Real Wood cabs and spare parts =)
    - Crossovers... I need to find the schematic w/ the TL mod, and a parts list. I'll see what I can dig up. Ugh... I haven't priced caps and such since January...
    The CRS+ I got were sooooo wrecked.
    I basically bought rough cabs, passives, and a dream.
    - Has anyone tried them without the cage over the passives?
    SDA CRS+ 1990 SL3000/RD-0198 mod in the SDA vintage speaker section
  • Looking forward to hearing your impressions when they are phase plugged and foamed.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
    xschop Posts: 5,417
    Looking forward to yet another build reveal soon. Think the CRS community is growing.
    Viking64 Posts: 7,629
    Can there be a $500 fine levied for each verb used as a noun?
    xschop Posts: 5,417
    To pug, or be pugged?
  • I got a degree in words so I can Shakespeare and Jabberwocky as I wish.
    As long as we understand the point, the Queen's English can hang back and enjoy.
    I used to be quite uptight about proper English. Then, albeit kicking and screaming, some great linguistics' courses (mostly) cured me of that.
    I did swap in plugged/foamed mids at the stereo positions.
    I know DK used some worn mids for his eval of the plugs, but mine are in great shape.
    I also don't know if he played with different configurations (plugged in stereo slots, plugged in SDA slots, plugged in all slots).
    I have plugged mids in the stereo slots right now, and the placement of sounds and width of soundstage are both fantastic.
    Stock crossovers, 194, re-did the alignment of the polyfill sheet, stock drivers in SDA slots, plugged drivers in stereo slots.
    I'll swap in the stock mids again, when I make the new crossovers, so I can do some structured evaluation.
    Next step, on these, is to build those crossovers and buy another pair of 198...
