Monitor 4 upgrades
2456
  • DeRod
    DeRod Posts: 249
    Got the grain flowing nicely from one panel to the next.
    "Equality is a myth to protect the weak. Some of us are strong in the Force, others are not. Only a fool believes otherwise." - Sith Proverb.
  • DeRod
    DeRod Posts: 249
  • DeRod
    DeRod Posts: 249
    edited November 2025
    Got the tops on the first 2 speakers ..
    Going to let them dry a bit and then do the fronts.
    I like how the grain on these look. I’m thinking to just use a clear gel
  • DeRod
    DeRod Posts: 249
  • DeRod
    DeRod Posts: 249
  • daddyjt
    daddyjt Posts: 3,131
    Maybe phase plugs and dynamat inside the baskets of the woofers would do the trick…?
    ― Aleksandr Solzhenitsyn
  • slow_polk7
    slow_polk7 Posts: 58
    DeRod wrote: »
    You should investigate tung oil (the 100% real stuff - not fake tung oil like Watco, etc.)
    mhardy6647 Posts: 35,203
    daddyjt wrote: »
    That's the kind of outside-the-box, innovative thinking this thread needs!
    I was thinkin' biamp and PEQ with DSP... but it would be so less elegant.
    B)
    F1nut Posts: 51,962
    Maybe convert the port hole to a mini PR.
    nooshinjohn Posts: 25,991
    Needs more cowbell....
    Airhole, yes?
    Oh... my mistake! Those are for subwoofers. :blush:
    https://forum.polkaudio.com/discussion/42762/should-i-have-an-airhole/p1
    I think the Monitor 4 will do a pretty good job with the cowbell... unless the XO to the tweeter is too high [EDIT] low. In that case, it might get a bit dicey. The phase plug'll def. help, though.
    I like @F1nut's idea, too. Pretty sure PartsExpress has itty-bitty PRs. Otherwise, I guess the OP'll have to bore and stroke his airholes... I mean... port holes.
    pitdogg2 Posts: 27,249
    We could call it a belly button passive.
  • DeRod
    DeRod Posts: 249
    @mhardy6647 Hey man you know there places you can go get help for your drinking problem right? Good luck with that bud 👍
  • DeRod
    DeRod Posts: 249
    I cut some new foam .. these are less thick than the others one I cut out. This also looks like what was originally in the speakers
  • DeRod
    DeRod Posts: 249
    Going to glue the diffraction pads this morning.
    xschop Posts: 5,369
    DeRod wrote: »
    Give him a pass. Probably just the excessive expression or cytoplasmic post-translation modification as of late. ;)
  • DeRod
    DeRod Posts: 249
    I even offered to sell that bone head my crappy speakers when I finish 🤣
  • DeRod
    DeRod Posts: 249
    Someone on another forum suggested only using diffraction around the bottom of the Peerless tweeters but not the top .. I’m going to try both ways the see it there’s a difference
  • How permanent is that fabric glue? Can you remove the wool in the future and clean off the residue if you so choose? I had thought about trying "gummy glue" sticks like what they use when they send you a credit card stuck to a piece of paper. I think the problem was having to buy a special low temperature glue gun but I didn't pursue it much. Maybe one could throttle down a standard glue gun with a speed control.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • DeRod
    DeRod Posts: 249
    That one works good. Fabric on fabric its pretty much permanent but on metal or plastic it rolls up like the gummy glue.
    xschop Posts: 5,369
    If you're brave, remove the faceplate, heat a large marble in water and drop it in the back side of the dome and roll around. Works on a dented wuhan. B)
  • DeRod
    DeRod Posts: 249
    At some point I took the Peerless from the 1983 pair and put those in my Monitor 7Cs as an upgrade to the SL1000. That was the nicest pair I had, they looked basically brand new.
    The ones with the lumpy domes came out my mini-monitors. Those had a foam grill that mashed up the tweeters.
  • Gardenstater
    Gardenstater Posts: 4,802
    I put a large chunk of open cell foam between the tweeter and MW, only I put it on top of the wool. I liked the results so much that I kept it, despite looking ugly (I don't listen with my eyes). I believe it helps reduce vertical lobing and comb filtering from interference around the crossover point.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
    F1nut Posts: 51,962
  • DeRod
    DeRod Posts: 249
    @F1nut Choo-Choo 😜
  • DeRod
    DeRod Posts: 249
    Train wreck or not the veneer is looking nice 👍
    The top photo shows the bottom where the grain runs out so I aligned it as best as possible to make it look like its flowing to next panel even though it’s not.
    Post edited by DeRod on
  • Coo Coo Baby. If that's a train wreck you should sell tickets LMAO.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • DeRod
    DeRod Posts: 249
    Next a light sanding to get the edges a bit better then to figure what finish to go with.
    I got enough veneer for the other 2 monitor 4s and probably a pair of monitor 5s. This is practice leading up to the veneer on my SDAs that I want to do in some fancy maple.
    @F1nut showed me a super cool video a while back using dye. If a can manage that on the SDAs I'll be very happy
  • DeRod
    DeRod Posts: 249
    If I did sell tickets @mhardy6647 would be the first to buy some .. he loves these little speakers. He was commenting on how great they sound and dreaming of having a pair 🤣🤣🤣 ... of speakers that is 🤣🤣🤣🤣
