Polk SDA 2 A and Fosi amplifiers
I recently acquired a pair of S D A 2 A speakers. Really like the sound especially after getting an interconnect cable. At the moment I am using a Yamaha R-N500 to power the speakers but it does run out of steam. I was looking at a Fosi ZA3 or V3 as a replacement but cannot confirm if it is a “common ground” amplifier which is supposedly a deal breaker for the SDA. Does anyone know about this or can confirm a cheap power amp, under , $150 that would power the SDAs properly.
Thank you in advance
B&K ST 2020 power amp
Onkyo P3300 pre amp
MCS 6500 turntable
Magnavox CDP 500 CD Player
Polk SDA 2 speakers
Pioneer RT707 Reel to reel
Wiim Ultra streamer
    xschop Posts: 5,101
    edited November 12
    You have to build a Dreadnaught to be able to use TPA-3251/55 based amps with SDA's. BTDT
    pitdogg2 Posts: 26,974
    The SDA 2a starts at 4 ohm and drops to the low 3 ohm area as well. That is why the receiver ran out of gas, those speakers will suck it dry faster than it can make power. Most receivers will struggle with a 3 ohm load.
    xschop Posts: 5,101
    The V3 will handle the low ohm load, no problem.
  • modplod
    modplod Posts: 10
    But is the V3 a common ground amp. Dont want to damage the speakers. Was also thinking about an older power amp like maybe an NAD. I do have a sonance 275 x3 but was told it is not a common ground amp
    Onkyo P3300 pre amp
    MCS 6500 turntable
    Polk SDA 2 speakers
    Wiim Ultra streamer
  • modplod
    modplod Posts: 10
    Pardon my ignorance but what is a dreadnaugt?
    Onkyo P3300 pre amp
    MCS 6500 turntable
    Polk SDA 2 speakers
    Wiim Ultra streamer
    Dreadnought is a audio grade torrid that allows you to use non-common ground amps, YOU cannot use it on 99% Blade/blade Polks and you cannot use it on the SDA2 a
    https://forum.polkaudio.com/search?domain=all_content&query=dreadnought&scope=site&source=community
  • invalid
    invalid Posts: 1,451
    edited November 12
    I owned a pair of sda2a speakers since 1987 and they need a lot of current to shine. I blew up 3 different receivers with the sda2a, the fosi might drive them but it's not a good match for them. Save up some coin and get a used parasound. They love current, the best I've had them sound is with my Krell ksa 300s amplifier.
    F1nut Posts: 51,710
    That's a big Hell No!
    xschop Posts: 5,101
    edited November 12
    Thanks for adding the blade/blade issue with isolation transformer.
    The OP could ohm out the neg- terminals on the V3 and find out quick if it is common ground. The Aiyimas and the 3E Audios are not CG.
    There's always the venerable smoke test lol...
  • modplod
    modplod Posts: 10
    The SDA speakers I have do not have the blade/blade plug for the interconnect. The have
    blade/pin
    Onkyo P3300 pre amp
    MCS 6500 turntable
    Polk SDA 2 speakers
    Wiim Ultra streamer
    That sounds like SDA 2b. They are a much easier load on gear. 6 ohm IIRC
    F1nut Posts: 51,710
  • odcics2
    odcics2 Posts: 373
    invalid wrote: »
    Parasound Halo A23+ at a minimum.
  • modplod
    modplod Posts: 10
    My speakers look like this and as I said they have the blade/pin plug for the interconnect
    Onkyo P3300 pre amp
    MCS 6500 turntable
    Polk SDA 2 speakers
    Wiim Ultra streamer
    SDA 2b all day.
  • modplod
    modplod Posts: 10
    Is there a difference in amp requirements?
    Onkyo P3300 pre amp
    MCS 6500 turntable
    Polk SDA 2 speakers
    Wiim Ultra streamer
    modplod wrote: »
    One thing about Polk Speakers is they love lots of current. The 2b will not be as demanding as the 2a. they can also use the dreadnought with non-common ground amps.
  • Gardenstater
    Gardenstater Posts: 4,770
    Were these previously owned by MP?
    2B or not 2B but Matt's is the question.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • modplod
    modplod Posts: 10
    I don’t know who MP is but I am in N California and picked them up for $100
    Onkyo P3300 pre amp
    MCS 6500 turntable
    Polk SDA 2 speakers
    Wiim Ultra streamer
  • modplod
    modplod Posts: 10
    Is it possible to buy a dreadnought and how much would one cost. I have getting more online but have not been successful
    Onkyo P3300 pre amp
    MCS 6500 turntable
    Polk SDA 2 speakers
    Wiim Ultra streamer
    modplod wrote: »
    @VR3
    Most of us built our own. Maybe @VR3 can help you, I'll let him chime in.
    F1nut Posts: 51,710
    modplod wrote: »
    MP is Matt Polk. His post was humor.
  • modplod
    modplod Posts: 10
    Ooops. Sorry
    Onkyo P3300 pre amp
    MCS 6500 turntable
    Polk SDA 2 speakers
    Wiim Ultra streamer
    audioluvr Posts: 5,890
    Do they say "SDA 2 A on the back of one? I wonder if those are my old ones.
  • modplod
    modplod Posts: 10
    I had a closer look at the label on the rear of the left speaker
    I also got hold got hold of a B&K ST2020 power amp and this is like night and day compared to the Yamaha I was using to power the Polks. The Yamaha would be running out of steam at higher volumes and the B&K is barely at a 1/3 volume.
    Onkyo P3300 pre amp
    MCS 6500 turntable
    Polk SDA 2 speakers
    Wiim Ultra streamer
    My old ones had that SDA 2 but then a square sticker with red background and a white A. But later found out they were actually B's
