The Best Rated 70 inch tv
williamson12
I've been looking into LED TVs for a few days now because I’m planning to upgrade my entertainment setup. I went through dozens of reviews from trusted sources like Consumer Reports and tech forums, and two models are consistently showing up at the top.
Samsung 65-Inch DU7200 Series
TCL 75-Inch Q6 QLED Series
Now, I’m stuck between these two and would love your expert advice.
In my home, we use the TV for movies, sports, and occasional gaming. I’d love good motion clarity, great colors, and a sleek design that blends into the living room.
So based on what I’ve read:
The Samsung DU7200 offers solid upscaling, Motion Xcelerator for smoother scenes, and good integration with Samsung's ecosystem. But it's 65", which might feel small in a larger room.
The TCL Q6 QLED is 75", has Quantum Dot tech for vibrant color, supports Dolby Vision, and seems better for cinematic experiences and larger spaces.
I’m leaning toward the TCL for the screen size and QLED picture, but I wonder if Samsung’s software and reliability make it a better long-term buy.
Which one would you recommend for my needs? Any insight would be really appreciated.
Thanks in advance!
Thanks in advance!
I've never heard of TCL.
Another TV discussion for your viewing pleasure.
https://forum.polkaudio.com/discussion/201494/new-tv-recommendationsPolitical Correctness'.........defined
President of Club Polk -
rtings.com extensively tests and reports (for free) on dozens of models.
Which is best changes frequently and depends on your usage - TV, movies, sports, HDR, gaming, etc.
From what I've seen, for decades Samsung has been one of the top five most reliable brands but TCL has never been one of the top five.Expect that there will be bumps in the road. Choose to not let them rattle you.
Boston - CR7, CR6s, CR4s.
Thompson Adventures, Inc. -
*all connected w/Premiere ICs
4 dedicated 20A feeds; APC H15; 5 Furman Miniport 20s -
Nah, haven't had a need for a new TV.Political Correctness'.........defined
hi friend , i am here to tell about my personal feedback. i bought samsung 65 inch class https://www.amazon.com/Samsung-65-Inch-Tracking-Processor-upscaling/dp/B0DXMT6CJP/?th=1 about 1.5 year ago. it has high quality resoultion and gives 4k vies and svcenerio. my homers like it very much.
^ “my homers” ^ 🤣
At the top?
Can’t be the top of much at $400.
In that price range get the cheapest you can find, you won’t see a difference.
The best 70”, 80” or 65” TV’s are the same…
Sony Bravia XBR Master Series.
Pay the price or compromise/settle as to what you can afford.
Sorry for the bluntness but your title said “Best”.
