The Best Rated 70 inch tv
I've been looking into LED TVs for a few days now because I’m planning to upgrade my entertainment setup. I went through dozens of reviews from trusted sources like Consumer Reports and tech forums, and two models are consistently showing up at the top.
Samsung 65-Inch DU7200 Series
TCL 75-Inch Q6 QLED Series
Now, I’m stuck between these two and would love your expert advice.
In my home, we use the TV for movies, sports, and occasional gaming. I’d love good motion clarity, great colors, and a sleek design that blends into the living room.
So based on what I’ve read:
The Samsung DU7200 offers solid upscaling, Motion Xcelerator for smoother scenes, and good integration with Samsung's ecosystem. But it's 65", which might feel small in a larger room.
The TCL Q6 QLED is 75", has Quantum Dot tech for vibrant color, supports Dolby Vision, and seems better for cinematic experiences and larger spaces.
I’m leaning toward the TCL for the screen size and QLED picture, but I wonder if Samsung’s software and reliability make it a better long-term buy.
Which one would you recommend for my needs? Any insight would be really appreciated.
Thanks in advance!
    F1nut Posts: 51,774
    I've never heard of TCL.
    Another TV discussion for your viewing pleasure.
    https://forum.polkaudio.com/discussion/201494/new-tv-recommendations
  • CGTIII
    CGTIII Posts: 1,237
    rtings.com extensively tests and reports (for free) on dozens of models.
    Which is best changes frequently and depends on your usage - TV, movies, sports, HDR, gaming, etc.
    From what I've seen, for decades Samsung has been one of the top five most reliable brands but TCL has never been one of the top five.
    Boston - CR7, CR6s, CR4s.
    ​Thompson Adventures, Inc.
  • gp4jesus
    gp4jesus Posts: 2,019
    TCL has been around for 10+ years. You need to get out more
    *all connected w/Premiere ICs
    F1nut Posts: 51,774
    Nah, haven't had a need for a new TV.
  • habib
    habib Posts: 2
    hi friend , i am here to tell about my personal feedback. i bought samsung 65 inch class https://www.amazon.com/Samsung-65-Inch-Tracking-Processor-upscaling/dp/B0DXMT6CJP/?th=1 about 1.5 year ago. it has high quality resoultion and gives 4k vies and svcenerio. my homers like it very much.
  • skipshot12
    skipshot12 Posts: 1,972
    edited September 2025
    ^ “my homers” ^ 🤣
    At the top?
    Can’t be the top of much at $400.
    In that price range get the cheapest you can find, you won’t see a difference.
    The best 70”, 80” or 65” TV’s are the same…
    Sony Bravia XBR Master Series.
    Pay the price or compromise/settle as to what you can afford.
    Sorry for the bluntness but your title said “Best”.
