Thinking about trying a tube amp. Thoughts.
13»
  • bcwsrt
    bcwsrt Posts: 2,517
    Not too much! It came with a vintage Hytron upgrade when I purchased it. I went back to it after switching out the Chinese Psvanes to some 1951 Hytrons in the 6SN7 spots and haven’t looked back.
    Brian
    VR3 Posts: 29,554
    Abbas should be in that list... One of the best sounding dacs I've heard regardless of price
  • TroyD
    TroyD Posts: 13,124
    So, I’ve had a few tube amps over the years….Conrad Johnson and Heathkit mostly. Tubes are expensive but, really, unless you are into rolling tubes…..a set of power tubes will last a long time. I had one bad tube….which was a Chinesium issue and replaced under warranty. Biasing is not difficult and not something that is a constant task……
    So, why I don’t still use tube amps……I lucked into the MF gear and moved on from the Quads.
    Bass, depending on amp/speaker may be a little softer, less tight that you are used to but I would have zero issues going back to tubes…..but, I am also not as persnickety about details as Tom is, which is not a criticism at all….but tube amps aren’t for everyone
    heiney9 Posts: 25,515
    Now I'm thinking maybe a tube DAC might be an option to change things up a bit with my 2 channel & leave the HT as is.
    IMO, tube dacs in general add very little tube flavor. I have 2 of them and experience with others. Granted they are implemented more as a buffer than gain stages. Really, IMO opinion tube pre amps really are the best solution.
    Also if you're not willing to go a little bit down the tube rabbit hole and only run stock tubes, don't bother. I'm not saying you have be like me and track down every known tube, but the most fun with tubes is experiencing some of the rolling options. Tubes can transform a system.
    Again just my .02c
    invalid wrote: »
    bcwsrt wrote: »
    Phil is always wanting to try something different. I love it!
    You know I'm going to say be sure and check out LampizatOr options. One of the top five changes I've made to my rig. Of course, it all started out by seeing what DACs could do with the Geshelli Labs J2 DAC I got from you!
    How much rectifier rolling have you done with the Lampizator DAC?
    In my tube travels the rectifier has a very heavy influence on sound. It's amazing to hear the difference between a modern tube rectifier vs. something from the 50-60's. I actually prefer a tube piece of gear that is also tube rectified.
    edited August 2025
    heiney9 wrote: »
    Again just my .02c
    I'm going to amend this statement by saying if the entire output/input stage is designed around tubes then I'm sure the tubes will add something. My reference was to the tube dacs that use the tube more as a buffer.
  • invalid
    invalid Posts: 1,530
    heiney9 wrote: »
    invalid wrote: »
    bcwsrt wrote: »
    A lot of measurement types will tell you the sound difference is due to voltage drop, but I run 3b22, or 866a tubes which have the same constant voltage drop of 15 volts no matter how much current and they sound different from each other. The 3b22 is bright and the 866a are warmer sounding.
  • pearsall001
    pearsall001 Posts: 5,328
    Decided to nix the idea of trying a tube amp but still wanted to get some tubes in the mix.
    I really like the Parasound JC2 BP pre & A21+ amp combo and I also didn't want to part with the JC2 & replace it with a tube pre.
    In steps the ModWright Analog Bridge. Placed between the source & pre for now & putting it thru it's paces.
    I can switch between 6SN7 tubes & 6922 tubes on the fly by simply flipping a switch. A different presentation between the two for sure.
    Next I'll try it between the pre & amp. A very flexible piece that just might fit the bill nicely. Time will tell.
    nooshinjohn Posts: 26,002
  • pearsall001
    Man they look nice!! That's an awful lot of tubes to manage though. Plenty of power for sure. Thanks for the heads up but I'm staying with my SS amp.
