Polk ES15 rubber discoloration
polgeo
polgeo Posts: 13
edited August 2025 in Speakers
Can anyone with the same speakers (or similar) tell me if this discoloration on the rubber is normal? Speakers are 6 months old, not under direct sunlight and always with the grills on. I am not sure but I remember when I first unboxed them they were pure black.z267k0gm2obh.jpg
    treitz3 Posts: 20,239
    F1nut Posts: 52,244
    It's normal for butyl rubber to change color tone as time passes.
  • polgeo
    polgeo Posts: 13
    OK, but is it normal for 6 months speakers out of the box?
    F1nut Posts: 52,244
    I can't tell you what is normal. I can tell you your surrounds look fine. Put the grills back on and enjoy the music.
    F1nut Posts: 52,244
    These are 10 year old S20 drivers. The surrounds pretty much look like yours, so I suspect yours won't change much from what they are now.
    pitdogg2 Posts: 27,686
    Is there smoking in the house?
    F1nut Posts: 52,244
    Polk promo pic off the Net. Center cap is much blacker than the surround. In fact, looks just like yours.
  • polgeo
    polgeo Posts: 13
    Since I can't sleep i tried very gently wiping that brownish residue with some cotton, and boom, after 2 or three passes It became like new again. Definitely looks like rubber oxidation. ue5gwa5jklgu.jpg
    F1nut Posts: 52,244
    Looks the same...lol
  • polgeo
    polgeo Posts: 13
    Not really, you can see the cotton, it removed most of the "stains".
  • voltshock
    polgeo wrote: »
    did you use anything on the cotton like water or something?
  • voltshock
    I found this for sale, is this the same discoloration you mentioned? Is this still good?
    The color looks different from what I see on google.
    F1nut Posts: 52,244
    That's just oxidation. Use regular Windex sprayed onto a soft cotton cloth, then gently wipe the surround in a circular motion.
    mhardy6647 Posts: 35,458
    This is a funny thread... not the like a clown kind of funny.
  • polgeo
    polgeo Posts: 13
    edited August 2025
    voltshock wrote: »
    polgeo wrote: »
    Only water, and made 3-4 passes very gently
  • polgeo
    polgeo Posts: 13
    voltshock wrote: »
    No, this looks white, I think is called blooming. The discoloration I mentioned is more likely "brownish". But as you can see the cotton removed it.
    This works really good^^^. It will take off the brown oxidation better than water alone. For future reference.
