Teac A-6300 R2R For Repair
  • SeleniumFalcon
    SeleniumFalcon Posts: 4,285
    No, that's not one I've seen in person. But, you can definitely see the family resemblance to your deck. Probably designed by the same team. The transport sections sometimes show up for sale without the electronics for reasonable prices.
    SCompRacer Posts: 9,090
    edited March 24
    There is an original owner A-7300 near me on FB Marketplace. Price dropped from $4K to $2,500. :o It was a top of the line consumer version similar to the studio version 25-2.
  • SeleniumFalcon
    Here is a link to a YouTube video done by Victor Komenko about using the 25-2 with an outboard preamp:
    https://www.youtube.com/watch?v=TSKyNhZKj3Q&t=38s
    edited March 26
    Nice tape pre!
  • SeleniumFalcon
    edited March 26
    Yes, I built one based on the P5 minus the capacitor bank upgrade, super easy chassis to work with. Take out a whole bunch of screws and the entire board with rear panel attached comes out. I think there are 19 or 20 screws holding the circuit board to the steel chassis, very rigid.
    edited August 15
    I've been slacking since March. I finally got back on the A-6300. Had some issues calibrating it in March after the recap, just let it sit. Near all the adjusting pots have a plastic shield. Dribbled some DeOxit in them, canned air them out. Much better.
    Been watching ebay. Got a nice condition original manual for the A-6300 for $25 shipped.
    When taking pics of heads, it helps to have a piece of paper under them to reflect light on them. I tried some thin foam packing material. It's a great diffuser but the heads reflect the irregular surface which hides the true condition of the heads. These have very little wear for the age of deck.
    Foam reflector under heads.
    Paper reflector under heads.
    Hopefully almost done..
  • schwarcw
    schwarcw Posts: 7,358
    Lookin' good Richee! The 6300 is a beautiful piece, built like a tank!
    Carl
    Thx Carl! You or Ed need another deck? :D I have four here, too many. Pioneer RT-71, Teac 4010SU, A-6300 and X-1000r.
    edited September 11
    The A series are sooooo easy to troubleshoot/repair compared to the X series, they are fun to work on. So, I snagged another A-6300 at a great price.
    It had this sticky grease film on it. Seller said it was from an aunt's estate, no idea. The film laughed at Simple Green. Had to use rubbing alcohol to get it off. Fortunately, it didn't smell like a cigarette. Lots of dust inside.
    Heads not worn too bad. Wood sides beat up a little. You can tell they tried to play a tape. Has the typical Teac issue, pinch roller linkage froze due to dried grease. After cleaning, I stuck a good pinch roller and a tape on it, forced the pinch roller linkage up, just press play. It played and sounded pretty good in FWD and REV so ordered a belt.
    First two pics from seller ad.
    A little better... Still needs some work. Polish the stainless. Clean and lube, DeOxit switches, pots, calibrate, etc....
    edited September 18
    When the front edges of the veneered wood sides are beat up worse than the rear, and you don't have Jesse (F1nut) woodworking skills, you repair best you can, drill new dowel holes and flip them 180.
    EndersShadow Posts: 17,700
    Just like a Futon!
    edited September 19
    Output and minimum input levels all calibrated well on A-6300 deck two. But, trouble in paradise. Bias trap adjustment, connect scope to test points, press REC and PAUSE, adjust to minimum. I don't expect exact readings between channels, but they should be much closer. Scope channels set to same division.
    Even though something isn't quite right, I go to next step, adjust bias. (The bias oscillator spec on this deck is 100kHz +-5%. You need bias to be able to erase/record on the tape).
    7kHz signal at -18dB. I can't get the range on the R channel. The SM tells you adjust for peak with trim pots VC401/402, then decrease by 3dB. I can't get much of a peak on R channel. (Teac used the overbias method, but I adjust bias by alternating between 1K and 10k signals but for now something isn't right). OH, I'm really enjoying the two channel dB meter!
    One of the trim capacitors doesn't feel right and gives erratic adjustment. I remove VC401/402 trim caps and test. One is 10-76 pf, the other is more fixed, tops out at 46pf (spec is 80pf).
    A piece of clear mica falls out of the faulty one. Now I get a better range, but it still tops out at 46pf. I ordered a couple. For now, I reinstall but swap channels.
    Now I get this adjusting bias traps. Scope channels set to same division. It's not uncommon for them to be slightly different. Much better! My bias range is much better too but still need to replace the trim pot. Set this on the side until parts get here.
    Bias oscillator board VC-401/402 tied into L302/304 bias trap so guessing the broken mica in the trim capacitor was the issue.
    Post edited by SCompRacer on
    edited October 6
    Well duh, mount holes are not centered in sides, so no flip 180.
    However I got some nice Walnut from Aaron's dads tree farm.
    edited October 12
    On deck pics. First, original side panels repaired, dark Mocha stain to cover the sins and clear satin poly top coat. An untouched OEM side panel at left. My early serial 6300 side panels had a counterbore as they used a shouldered mount washer while the later serial had flat mounting washers.
    New Walnut side, Watco Danish oil with satin poly.
    The right side Walnut panel.
    Left, late side panel mount hardware (17xxx) right, early (11xxx).
    I had three Walnut panels to choose from. This one had some dark areas and didn't match first two Walnut side panels, even though you can't see both sides at same time.
    edited October 13
    Cherry sides, first coat Tung oil.
    edited October 18
    The new hardwood sides get a finishing touch. I obtained some aluminum anodized shouldered washers and M4 Phillips head Stainless screws with black finish. (Allen and Torx head are also available). They replace the OEM flat head screws with plastic shouldered washers. Sometimes the OEM screws are in sad shape from poor storage or stripped from using Phillips instead of JIS drivers.
    You can get the shouldered aluminum washers in various sizes at ebay or Amazon. They offer different colors too. I went with black on black. I liked the contoured head of these screws better than new flat ones. I guess you could call them a flattened pan head. The seller only had these style M4 screws 60mm long so I cut them down to the 22mm length needed.
    I had to use M5 washers as the M4 screw head (8.7mm) is too large for the M4 recess (6.8mm). (They are sized by hole in washer). The recess in the M5 is ~9mm while the head of the M4 screw is ~8.8mm so it's a snug fit. The OD of M5 aluminum washer is the same diameter of the OEM screw head.
    I liked the shape and gloss to match washer. One could go with bright stainless screws too.
    Other option, flat head with a flatter finish.
    A taller Fisheye style washer is available.
    Two coats Tung oil.
    OEM left.
    pitdogg2 Posts: 26,980
    SCompRacer wrote: »
    By far my favorite wood, for furniture and smoking.
    edited October 18
    Aaron has me thinking about a Cherry (or ????) cabinet for the X-1000r to replace the OEM fake vinyl wood wrap cabinet. The capability regarding tools is there at his brothers shop for the perfect sized square cabinet. The difficulty is all the thin shim pieces inside. Lots of (cue Hervé, The plane! The plane!) planing work.
  • schwarcw
    I say do it also! The X-1000 cabs are really cheaply made.
    Carl
