True 2-Channel Analog Additions
Posting some pics of my Zenn/Klipsch MCZ cartridges here. I already owned a couple of the Klipsch MC carts (and love their sound), so couldn't help but pounce on some NOS (unused) Zenn MCZ carts from a collector in Ireland. My recent (Zenn) acquisitions are on the left in these pics, and vintage Klipsch cart packaging on the right.
Specs on these carts are easy to obtain, but in summary, they are LOMC, with a low compliance.
The most exciting item from my latest haul is a NOS Zenn MCZ/7, which has a Boron cantilever.
I've had an MCZ-2(?) re-tipped with a boron cantilever for a while, but IMO, it has always sounded a little too polite for my system. I am interested to hear how this MCZ-7 with 'native' boron cantilever sounds.
    Clipdat Posts: 13,104
    edited February 2023
    Congratulations Jody on your new cartridges. Will these primarily be collector's items or are you planning on putting them to use?
    msg Posts: 10,650
    Clipdat wrote: »
    Moment of truth, @jdjohn -Jody - pick a side.
    I've historically had a bad habit of picking up two of things I thoroughly enjoy. One to use, and one (or more) as a backup. (You know, for when jackleg manufacturers discontinue the things I like.) This is impractical for a number of reasons, obviously. Further, I'm still afraid, sometimes, to use the one that's for using!
  • jdjohn
    jdjohn Posts: 3,443
    I will definitely be using them! Hopefully the suspensions are still good :#
    I also took a few pics of my Micro Seiki LC-40 cart.
    This cartridge is actually a two-piece design, where I suppose the intention was to have a replaceable stylus.
    I've never seen the separate stylus for sale anywhere...shame. This has a very low output - less than 0.2mV.
    Don't be afraid, Scott! Use yours!
    My question is: why did I choose such a goofy name for this thread? I guess with all the recent chatter about DACs, networking, and streaming, I wanted to show analog a little love here <3
  • bcwsrt
    bcwsrt Posts: 2,691
    Made me click on it!
    Brian
  • jdjohn
    jdjohn Posts: 3,443
    Many folks know about the Grace F9 cartridge as being one of the best MM carts ever made. The SF-90 is basically the same cartridge, but integrated into a headshell. The SF-90 is somewhat rare, but does pop-up occasionally in the aftermarket.
    I obtained two examples of the SF-90, with this set having much of the original packaging.
    I removed the protective stylus sleeve for this pic.
    Those who are informed know that SoundSmith still makes hand-made replacement styluses for the F9. In this pic, I've installed the RS-9U replacement, which has an aluminum cantilever.
    Top view:
    The original Grace F9 stylus body has a rounded shape, but I actually like how the SoundSmith replacement continues with the angular look.
    Obviously, the integrated cartridge/headshell configuration does not allow for alignment adjustments, but I have found that tonearms with pivot-to-spindle lengths in the range of 222-230mm will work fine with the SF-90.
    Since the F9, and SF-90, are high-compliance, a lighter mass tonearm is more suitable. I have also found that a lower capacitance load sounds better.
  • jdjohn
    jdjohn Posts: 3,443
    Another installment here, this time of the Technics EPC-205C MM cartridge, and a couple of NOS styli I found. The EPC-205C is one of the better(best?) MM carts ever produced. These are well-regarded enough that JICO still makes several different replacement styluses for them, ranging from simple aluminum cantilevers with bonded tips, up to boron and sapphire cantilevers with the famous JICO SAS diamond tips.
    Again, for this post, I found two NOS replacement styli. First, an EPS-205EX, which I think was the standard stylus on the EPC-205IIX cartridge. This stylus even came with original packaging, and although the box was opened, the case was still sealed.
    Here it is mounted on the cartridge.
    Here's a close-up of the cantilever and diamond.
    I thought this might have been a gold-plated boron tube, but I think it is actually a titanium tube since the end is crimped a bit.
    Next is the EPS-405QD, which is a nude Shibata stylus.
    Here it is mounted on an EPC-205C cart.
    Here are a few different closeups of the tip.
    Notice the typical Shibata scalloped facets on the rear of the diamond. Still breaking this one in, but it seems to really minimize vinyl surface noise. Luckily, the suspensions on both of these still seem to be intact.
    Good stuff, Jody!
  • BlueBirdMusic
    BlueBirdMusic Posts: 3,132
    Jody some really great detailed photos.
    Harry / Marietta GA
  • jdjohn
    jdjohn Posts: 3,443
    I've got a couple of Fidelity Research cartridges to post about. My newer acquisition is a PMC-1 MC cart. It has a cool, red glossy finish.
    The stylus is not the clearest, or prettiest, gem, but still a nice nude elliptical, mounted on an Aluminum cantilever.
    The unique thing about these cartridges is that they have 'air coils', which basically means that the coil wires are wrapped around a non-ferrous core. This equates to less moving mass, which is a good thing.
    The resulting sound caused me to document a few initial notes.
    - I'm a fan of Eva Cassidy (RIP), thanks to my wife, and with this cart, I found her voice even more soulful, and the musicality of the accompanying players also jumped out at me more than before.
    - While listening to some Genesis tracks, I picked-up on an extra drum beat (eighth or sixteenth note) that I had never noticed before.
    - Some Atlanta Rhythm Section tracks also had extra depth and detail that were new to me.
    Overall, I noticed greater dynamics from quiet and loud passages, with more layering of sounds from front-to-back, so basically, more depth. Apologies for not having a direct A/B comparison cartridge to mention. All of the above bullet points are exemplary to my previous listening experiences, which is to say: the PMC-1 may have exceeded the sound quality of all my previous cartridges. Needless to say, I am really enjoying it, but I realize there are many other modern, higher-end options out there. Personally, I just love playing around with these vintage beauties B)
    While on the subject of Fidelity Research cartridges, I thought I'd also include the FR-6SE, which I think may have been their best MM cart.
    The original stylus was a nude-mounted square-shanked elliptical, and this cart is in my MM top 5, especially in the low-compliance realm. Sadly, replacement styli are non-existent. I would describe the sound as one click towards warm, yet still analytical.
  • jdjohn
    jdjohn Posts: 3,443
    Recently, there has been somewhat of a surgence of new Chinese MC carts coming onto the market. As everyone knows, the Chinese are quite capable of copying original designs of practically anything, and they typically manufacture 'cheaper' versions. Of course, there are always concerns about quality, in both materials, and skill.
    I took a chance, and bought two new MC carts from Chinese eBay seller es_hovertech_audiolab. One cartridge has an Aluminum body, with a Boron cantilever; the other has a Sandalwood body, with exposed internals, and a ceramic rod cantilever. Both cartridges have an elliptical stylus, from unknown origin.
    Here are pics of the carts as I received them. One box had a clear acrylic lid, and the other box was all wood, but I removed the wooden lid for the pic.
    Here are individual shots of the cartridges in their boxes.
    And here are the cartridges mounted (sorry for the graininess).
    Specs for the Aluminum body, Boron cantilever cart:
    -Cartridge type: Stereo moving coil cartridge
    -Needle point shape: super elliptical
    -Needle rod material: Boron rod
    -Shell material: Aluminum alloy
    -Cartridge weight: 10.6g
    -Coil type: 5N OCC
    -Output voltage: 0.34mv (1KHz, at 5cm per second speed)
    -Phono impedance: 9Ω
    -Frequency response: 20-25KHz±2dB
    -Channel separation >28dB
    -Left and right channel balance <0.5dB
    -Recommended injection pressure: 1.8g
    -Recommended acupuncture pressure range: 1.7-2.3g
    -Shield compliance: 15um/mN
    -Break-in time: 20 hours
    Specs for the Sandalwood body, ceramic cantilever cart:
    -Needle point shape: super elliptical diamond stylus
    -Needle rod material: Ceramic rod
    -Shell material: black sandalwood
    -Cartridge height: 18.2mm
    -Cartridge weight: 6.5 g
    -Coil type: 5N OCC single crystal copper
    -Output voltage: 0.45mv (1KHz, at 5cm per second speed)
    -Phono impedance: 6.5Ω
    -Load impedance:>=60Ω
    Both cartridges have threaded inserts in the body for mounting, so no screw nuts are needed.
    Here are some close-up pics of the stylus from the cartridge with an Aluminum body, Boron cantilever, and elliptical diamond tip:
    The diamond has a yellow hue, which is not necessarily bad, but the overall appearance suggests that these diamonds are only average quality, which is to be expected at this price point.
    Bottom of the stylus after several hours of playback (I've circled the contact patches):
    Here is the entire cantilever assembly, including the coils. I think the highly reflective piece is the bottom of the pole magnet.
    Next, here are some close-up stylus pics of the cartridge with the Sandalwood body, ceramic cantilever, and again, elliptical diamond tip:
    This diamond has a darker appearance (at least from the front view) - not sure if that is from light diffraction, or a 'black' diamond, or what.
    Here's a bottom shot of the diamond after several hours of playback; the contact patches look small, as would be expected from a new cartridge.
    Entire cantilever assembly:
    Here, the right/left coil wires are circled, showing how they are hot-glued to the sides of the generator.
    Here are the coil wires routed to the back pins.
    Shot of the tension wire, and how it goes into the generator:
    As far as sound, I am finding them to be very detailed and balanced. No brightness or sibilance, and very full-sounding in the bass. I'm still evaluating, but so far, I like what I'm hearing.
  • BlueBirdMusic
    Jody, your descriptions and photos are phenomenal.
    Harry / Marietta GA
    billbillw Posts: 8,288
    edited September 2024
    Thanks for the writeup and detailed photos. I'd suspect the wire is not 5N OCC and the diamond shapes lot a lot more conical than elliptical, but otherwise, pretty nice quality. How does the price compare to the more established brands from Europe or Japan? 20, 30, 50% less?
  • skipshot12
    skipshot12 Posts: 2,156
    I have a stupid question…..
    How much of a difference does the quality of the diamond have with sound reproduction?
  • jdjohn
    jdjohn Posts: 3,443
    billbillw wrote: »
    Any particular reason for doubting the 5N OCC? The side views of the diamonds do look conical, but I can see the facet cuts on the front, matching an elliptical profile. But overall, I do think the cantilever and stylus leave something to be desired.
    These Chinese MC carts cost me about $400/ea. To get a boron cantilever, you have to move pretty far up the line with Hana, Ortofon, or Sumiko, paying well over $1,000. The Audio Technica AT33PTG/2 has a boron cantilever, and runs about $600. Ceramic cantilevers are new to me, so no real comparison for that.
    skipshot12 wrote: »
    As far as 'gem' quality, probably not much of a difference. In fact, some diamonds used for styluses are synthetic - grown in a lab. But the cut/profile of the diamond can make a significant difference. The diamonds on these Chinese carts have quite a bit of glue on them, so hard to get a really good look, but from what I can see, they look pretty simplistic.
    jdjohn wrote: »
    I mentioned that because real OCC 5N wire is hard to get and very expensive compared to generic copper wire that might be 3N without the OCC process. It is also very hard to verify or disprove something like that. Chinese manufacturers have been widely known to use slightly (or sometimes very) inferior metallurgy in many of their products. That alone doesn't really change the value of these cartridges. If they sound really good at 40-60% of the price, then I wouldn't give a 2nd thought of the wire used.
  • jdjohn
    jdjohn Posts: 3,443
    Not a new cartridge for me here, but I haven't played it in a while, so snapped a couple of pics.
    Signet TK7-SU with a TKN3 stylus:
    Signet was the 'luxury' brand of Audio Technica (think Acura>Honda, Lexus>Toyota), with (I think) one of main upgrades being metal bodies, but likely also higher tolerances in the coil measurements.
    Not exactly sexy in looks, but a very fine MM cartridge from the AT line. The TK3N stylus has a tapered Aluminum cantilever, with a nude Shibata stylus tip B) These are high-compliance cartridges, and sound best with a very low capacitance load.
    Nice! I always liked the price/performance of the higher end AT carts.
    SCompRacer Posts: 9,399
    edited July 2025
    I've had some expensive cartridges but prefer the AT33PTG/II in my system.
    My second air bearing arm has a Denon 103R with aluminum body. It's like a 30 second swap to change arms.
    A fav MM of mine is the Acutex M310 II E. It has the original stylus which is in very good condition. I've read replacement stylus are not as good, but that could be just someone's opinion. The replacement could be missing the shield the original has, can't recall exactly.
    I forget which AT cartridge is on my Mitsubishi LT5V vertical TT.
  • jdjohn
    jdjohn Posts: 3,443
    I have two AT32EII in my cartridge stable (would love to sell one :) ), but I know the AT33PTG holds a special place in the lineup.
    Not too long ago, I acquired an AT-F5 with low hours on it:
    I think the suspension might be on Viagra...very stiff :D
    For the last week, or so, I've had this Fidelity Research MCX-3 in the mix.
    It has been part of my 'source' chain for some recent test recordings on an Akai X-1810D RTR tape deck.
    edited August 2025
    That's quite a SRA! (stylus rake angle for you non vinyl guys).
    The MCX-3, designed by (for FR), in your best Samurai voice, say Ozawa-San! He started Shelter in '86.
  • jdjohn
    jdjohn Posts: 3,443
    I'm officially a member of the Lyra club B) Here's my Lyra Clavis Evolve 99:
    I bought this cartridge with a snapped cantilever, at a big discount, and had it retipped with a Boron cantilever and Line Contact tip.
    I can say that any hype about these cartridges is justified. The aspect that really jumps out to me is additional levels of dynamics. Separation and placement of instruments and vocals is (frankly) nothing new, but with this Lyra, there is another level exhibited.
    I'll try to describe it by referencing a theoretical range of dynamics. For example, let's say there are five different instruments in a musical passage, and each instrument (or vocal) has a dynamic range level between 1 and 10. With prior experience, most cartridges may have three of the five instruments at level 5, with another instrument at 3, and another at 8. That level of playback reproduction is actually quite impressive, and very satisfactory. But with this Lyra, the dynamic levels are now between 1 and 20, and each of the same five instruments has its own dynamic level, creating a more layered soundstage, and finer placement of each instrument.
    Trying this high-end LOMC cartridge with a few of my different phonostages has also been a bit of a revelation. It has made me appreciate some phonostages more, and alternatively, it's made me become a bit disappointed in at least one other.
    As I've continued listening to additional recordings with this cartridge, I think 'more refined' is another appropriate moniker...subtle revelations of new detail from the grooves.
  • Conradicles
    Conradicles Posts: 6,433
    Garage tunes via Analog
    Grabbed a couple of late 70s Sony pieces today to restore. Tuner works, but needs an alignment. Amp needs some PS parts replaced and then, who knows what else. I plan on taking my time through the Winter with these.
    TA-F6B and matching ST-A6B
  • jdjohn
    jdjohn Posts: 3,443
    Great pieces, gents!
    jdjohn wrote: »
    BTW, I think you take the cake for most phono carts tested. You really have tried a bunch. I like that head shell on the Lyra. Cool stuff. Are you holding on to all those or moving them out as you upgrade?
  • jdjohn
    jdjohn Posts: 3,443
    edited October 2025
    Thanks, I'm a habitual collector of phono carts. They're small, easy to store, and relatively cheap (for the most part). I must have over 75 right now :o But, most of them are much more run-of-the-mill than the ones I've posted about in this thread. Only a very few are 'new', although several are NOS.
    I wouldn't mind selling some of them, but it seems that most folks would rather have brand-new. Buying used (trust me, I know) can be tricky, especially when it comes to condition of the stylus (i.e., hours played, suspension, etc.).
    Oh, that headshell is an Orsonic. It's my best one, for my best cart :)
  • jdjohn
    jdjohn Posts: 3,443
    New (to me) acquisitions:
    Technics 300MC - Titanium Nitride (TiN) cantilever with nude elliptical stylus
    Panasonic 451C Strain Gauge - has a bonded Shibata (CD-4) stylus
    with Precision Fidelity SG Demodulator
    I believe it is well-documented that these Strain Gauge systems have a frequency response curve that is different, which I can confirm. There's a bump in the low-end, a defeat in the mids, and then a bigger bump in the highs, that doesn't roll-off until out of our listenable hearing range. For me, it's not a game changer, but more of an adaptation.
