How to wire Atrium8 SDI speaker and ceiling speakers to Denon DRA-800H amp
windsor_tg
in Speakers
I have 2 x ceiling speakers and these are wired to Output A on my Denon DRA-800H amp using the 4 terminal posts on the amp.
I recently bought the Atrium8 SDI speaker and wired this as a stereo speaker (using 2 x 2-core cables). The other end of these cables are wired to Output B on the Denon amp using the 4 terminal posts on the amp.
When I play music via Spotify through the amp, the sound is only coming through the ceiling speakers. What settings do I need to change so that I have the option to play music 1) simultaneously through both, the ceiling speakers and Atrium8 SDI speaker, and 2) only through the Atrium8 SDI speaker?
Hello,
Welcome to the Polk forum. After looking though the general instructions in the receiver's owner's manual (a pretty easy manual to navigate, actually) it looks like that subject is covered in the setup section. Here is page 130:
So, it looks like you use the remote to make choices on how the speaker select button functions, then you should be able to have what you're looking for.
