My deal of the century!
2
  • bcwsrt
    bcwsrt Posts: 2,414
    Yes, this is a cool story! Congrats!
    Brian
    SCompRacer Posts: 9,112
    edited July 2025
    When using a vacuum use the air bleed on the handle if so equipped to control the suction. You can tape smaller hoses into the larger vacuum pipe for a smaller surface area.
    HiFi Engine had a brochure and 17-page service manual. Sent via email. The SM has test point locations, lists voltages, even covers the remote. Very nice.
    EndersShadow Posts: 17,705
    No shop vac, if your regular floor vac has a hose that is what I used. The trick is have the wife flip the switch on/off just that quick.
    Honestly I think it will not get any better than that, great job Dan!
    Yeah I think it’s as good as it’s going to get. I’m leaving it the way it is for now.
    SCompRacer wrote: »
    I’m gonna take a look for sure at the remote schematics as the remote volume is a bit quirky as to how it works and how hard you have to push it to get it to register.
    Already swapped out batteries in it so I know it’s not that.
    edited July 2025
    I've had to dismantle and clean old remote contacts. A little DeOxit followed up with 99% iso alcohol.
    This was from a Melos SHA Gold headphone amp remote.
  • Conradicles
    Conradicles Posts: 6,343
    edited July 2025
    New legs came in, so I swapped them out. The original bolts worked but are a bit shorter than I’d like so I may swap them out at Lowe’s tomorrow.
    New feet also touch the heatsink which may/may not be a problem. Thoughts on that appreciated.
    If I get longer bolts I will get some metal spacers to go between the legs and chassis. They are slightly taller by just a bit but that’s not a bad thing.
    Overall 23 bucks v close to 120.
    Before
    Comparison of old (right) v new (left)
    Depth of bolt comparison. In the new foot it’s got a bit more depth as I was holding the foot at an angle to get this shot, but still could be improved.
    Heatsink overlap
    Final result
    Played a bit more with placement with my temp wiring.
    The Amp is plugged into one outlet the streamer into one on another wall so the power cables don’t overlap with the speaker wires much/at all.
    Speakers are 16” from the sides of the woofer cabinet with slight toe-in.
    Crossover and streamer got some rubber spacers added to them, because why not.
    Final result.
  • machone
    machone Posts: 1,559
    You could add a large diameter fender washer between the top of the foot and the amp to create an air gap between the foot and the heat sink.
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
    machone wrote: »
    Pretty sure that’s the route I’m going to take today.
    edited July 2025
    Mill or hacksaw some relief in the footers. :D
    Those are nice footers Dan.
    edited July 2025
    SCompRacer wrote: »
    Spacers are easier lol.
    Lowes had only standard sized for what I needed and I want to stick with metric so to Amazon I go.
    Options for standard
    edited July 2025
    A bastage file! :D
  • sgmsmg
    sgmsmg Posts: 556
    If you have an ACE hardware nearby they have a much better selection then Lowes or Home Depot.
    Pre: Bryston BR20
    Amp: Buckeye NCx500
    Speakers: Polk L200
    Source: Oppo UDP-205, Bryston BDP-3, Bryston BCD-3, Apple TV, Amazon Fire
    Cables: Wireworld Gold Eclipse 7 Speaker, Wireworld Gold Eclipse 7 XLR, AQ Diamond USB/HDMI
    Power: PS Audio P10 Regenerator, AC12, AC10 and AC5 Cables
    Display: Sony XBR65Z9F
    Pre: Anthem AVM90
    Amps: Buckeye NC502
    Speakers: Polk LSiM 707 (FL/FR), Polk LSiM706 (Center), LSiM 703 (SL/SR/SBL/SBR), Polk 900-LS (Atmos)
    Subwoofers: SVS SB16 x 4
    Source: Oppo UDP-205, Apple TV, Amazon Fire
    Cables: AQ Meteor/Rocket 88, AQ Niagara/Sky
    Power: Torus AVR20, Shunyata Denali, Shunyata Delta, Cullen, PangeaAC9SE Cables
    Display: Sony XBR85Z9G
    nooshinjohn Posts: 25,929
    edited July 2025
    ^^^Connie Stevens approves this message.
    https://youtu.be/UDIcmmtS_O4?si=YJOpZLI4VtJULc_0
    sgmsmg wrote: »
    Yeah I was thinking about checking there. Will hit them up after work.
    edited July 2025
    sgmsmg wrote: »
    Thank you @sgmsmg for the suggestion. I was shocked how much better stocked ACE was.
    Got just what I needed and had a ton of options to choose from. Ended up going with neoprene washer to space it and got two sizes of bolts but the shorter one worked just fine.
    The washer was a PERFECT fit for the foot as it was identical in size to the raised area on the plastic foot.
    Attached to the new foot
    Before the spacer
    After
    Also heard some rattling around inside so popped the top to find a small nut that was floating around. No ideas what it went to but removed it before it connected things that shouldn’t be connected lol.
    Some interior shots because I likely won’t open this again.
    Post edited by EndersShadow on
    billbillw Posts: 7,561
    It looks like you read my mind and put a rubber/foam washer between the chassis and the new feet. For this purpose, I think that is the best choice. Nice deal. Those original feet were not worth the asking price from Italy. They probably cost the company $5-$10 for a set and the rest was markup.
    Cool story all around, but I was confused...the person gave you the amp and DAC along with the free speakers? I would have expected they would want some cash for the amp at least. If it was all a free haul, that was very generous of them.
    edited July 2025
    billbillw wrote: »
    Yup all was free. I didn’t come expecting anything other than the speakers so it was a shock for me as well.
    He even shipped the DAC after the fact, still getting nothing. I obviously paid for shipping and materials cost, but still.
    billbillw wrote: »
    Yeah the price per foot they quoted was 11 per (so 45ish), then that same amount for freight shipping from Italy to CA, then add the distributors shipping to me lol….
    billbillw wrote: »
    Yup worked out well and you don’t even notice the neoprene washer.
    F1nut Posts: 51,787
    That was the magic nut you removed.
    All my responses to this would get me banned lol….
    So I will just say there are sooo many jokes to make off that.
    And here I thought he busted a nut…
  • halo71
    halo71 Posts: 4,632
    Perhaps its just me. But i think if I were given a piece of gear like that....I would buy the original feet from the manufacturer.
    --Gary--
    halo71 wrote: »
    They didn't seem to be of any special quality from the photos. Just plastic with a chrome/stainless outer cover. I don't think he's going for a museum piece here. It's an upgrade if anything.
    F1nut Posts: 51,787
    Those original feet are basic junk.
    edited July 2025
    My HiFi2000 chassis from Italy got stuck in customs over piede antivibrante (antivibration feet) and involucro elettronico (electronics enclosure). I had to convince them it was just a DIY DAC chassis. I may be on a watch list.
    edited July 2025
    billbillw wrote: »
    halo71 wrote: »
    Correct. The originals are plastic. The new ones that I’d get would be metal.
    I may eventually get the correct feet since it also appears I am missing the tube dampers from up front.
    billbillw wrote: »
    halo71 wrote: »
    Before you spend $$ for those original tube dampeners up front, they appear to be just a cage to protect the tubes from wandering hands, tails, etc. They don't actually touch the tubes, so they probably won't have much sonic effect. My LSA amp had those and it really just made it harder to swap tubes. If you want something that will actually affect the sound, get some real dampeners from Herbie's or similar.
    pitdogg2 Posts: 27,059
    I've bought both the cooling dampers and Herbie's, they both reside in my junk drawer now.
  • muncybob
    muncybob Posts: 3,241
    Same here, seemed to suck the life out of the music.
    Yep, my name really is Bob.
    Good to know. Might want em just to have because but prob in the same realm as the OEM feet
