Power to drive R700
rkevin
rkevin Posts: 8
I really wanted to buy the R700 today but the sales rep at Crutchfield told me my amp won’t effectively drive them. I have an Onkyo RZ 50. Only speakers I am driving would be the R700 plus 2 8 inch ceiling mounted speakers. If true, what are my options? I don’t want to add a sub due to wife restrictions. I have a full setup in another room. Do I need to consider other speakers? Add an amp ? Help is appreciated!
    pitdogg2 Posts: 27,047
    He was basically correct. Your receiver is rated @ 120 watts x 2. Will they make sound, yes. You will never get them to their full potential, also more easily blow tweeters or drivers due to clipping. The good news is that the receiver does have pre outs to add a dedicated 2 channel or multi-channel amp. It's not all about watts you also need good current (high-current) as well. If you end up shopping for an amp look for one that will basically double down. By that I mean if it is 200 watts per channel at 8 ohms then it should double to 400 watts at 4 ohms or very close to it. That's indicative of a good power supply. One of the things that receivers do is they cheap out on the power supply because that is actually the most expensive part copper and power, banks of large capacitors to store power for demanding passages of music or movie explosions etc.
    Also the more speakers the receiver is driving the less power goes to the speakers. Your receiver is rated at 120 watts per channel x 2. Driving four or five speakers at the same time you could be down to as little as 30 to 40 watts per speaker.
  • rkevin
    rkevin Posts: 8
    Thanks! Any suggestions on an amp that will produce the power I need? One person pointed my emotive, another to Cambridge soundworks (but I only saw lower power amps there)
    F1nut Posts: 51,771
    edited July 2025
    Emotive in the past had been a pretty bright sound signature. I'm not sure if they are still so try if you have a return window to do so. The McCormick is a end game amp for most, damn fine amplifier!
  • rkevin
    rkevin Posts: 8
    Im sure I would love the McCormick but I’m gonna cap out around 2000 to maybe 2500
  • rkevin
    rkevin Posts: 8
    After spending too much time this weekend this is where I lean - two Outlaw 2200 monoblocks (just under 1000 total ) OR there is a Rotel 1582 MKII demo unit I can have for $1200. Seems either would work well for me and the R700 s. Thanks in advance for your thoughts!
    edited July 2025
    Rotel would be my choice. Rotel can be a little sterile but they do not draw attention to themselves. I've had several friends that have had very dependable results with both the 5 channel and 2 channel versions in home theater or music.
    Their class D amps were horrible IMHO.
  • Emlyn
    Emlyn Posts: 4,708
    The Rotel 1582 MK II would be a good match. Good deal too if it's in good shape with a full warranty. Especially considering new retail is $2500.
    The Rotel class A/B are tried and true designs. Haven't really changed much in the last 30 years! Other than having different model numbers and casework for the faceplate. I think they've even been using the same WBT looking binding posts for 20 years.
    The R700s are marketed as having an 8 ohm nominal impedance. It's probably a little lower in reality and one of the reasons why the Crutchfield reps are saying to get a high current capable amp.
  • rkevin
    rkevin Posts: 8
    edited July 2025
    One last question - a local dealer has a new Emotiva XPA-2 Gen3 he will sell me for $750 with warranty. I'm inclined to do this unless I am making a terminal mistake. Thanks again!
    rkevin wrote: »
    Why not just spend the money saved and get a Emotiva 5 or 7 channel amp and use the Onkyo as a pre-amp/processor?
    Remember you get what you pay for. Many people are very happy with Emotiva gear for Home Theater.
    F1nut Posts: 51,771
    edited July 2025
    If you care about sound quality then it's a terminal mistake, IMO
  • rkevin
    rkevin Posts: 8
    rkevin wrote: »
    I only need 2 channels for this amp.
    Music or home theater?
  • Emlyn
    Emlyn Posts: 4,708
    Check out this video starting around the 10 minute mark to see the innards of the Emotiva XPA Gen 3 amp. Class H switching to class A/B. Big case with not much to look at inside. Fits well for home theater but it is what it is.
    https://www.youtube.com/watch?v=4TMgAW5yt_8
  • rkevin
    rkevin Posts: 8
    edited July 2025
    This will be used 90% for music. It will be attached to an AVR with the TV, but mainly only for sound boosting and some whole-home audio sources. Home Theater setup is in another room.
    Music, forget Emotiva.
    The Rotel is a much better choice
  • PSOVLSK
    PSOVLSK Posts: 5,381
    I’d vote for the Rotel also. I’ve owned both and I probably have a higher opinion of Emotiva that many on here, but Rotel is the better brand.
  • mrloren
    mrloren Posts: 2,474
    edited July 2025
    I like my XPA-3 works great on music and movies. I don't get why Emo gets such a bad rap on this board. Yes if I had the funds I'd have a Parasound.
    Also look at Monoprice and Outlaw 5000
  • Geoff4rfc
    Geoff4rfc Posts: 2,838
    I'll throw my wrench in here......I had my RTiA9's paired with a Gen 1 and Gen 2 XPA2, phenomenal sound in 2ch. The A9's lost the bright edge they first carried and produced Non fatiguing, detailed crisp music.
    Set up:
    Marantz AV8802A - Sources: BRP Panasonic 9000/CDP Emotiva ERC 3 - Display: LG OLED EVO 83 C3 - Amplification: Emotiva XPA-DR3, XPA-6, XPA-2 x 2 - Speakers: Focal/PolkAudio, Mains/2ch - Kanta No2, C - LSiM706, SS - LSiM702, WS - RTiA9, RS - RTiA9, FH - RTiA3 - Subs: Epik Empires x 2
    Cables: AQ McKenzie XLR's from CDP to AVP to amp for 2ch, Emotiva XLR's for the rest - Douglasconnection: Furutech Alpha 36 12g speaker wire for 2ch, Furez 10g speaker wire for the rest - AQ Forest48 HDMI for the display, AQ Carbon48 HDMI from BRP to AVP - VR3 filtered power cables for CDP, BRP and AVP, Emotiva power cables for the amps - AudioQuest 505 power conditioner.
  • Emlyn
    Emlyn Posts: 4,708
    I enjoyed the first Gen XPA-5 I had for a while. Bought it out of curiosity but sold it after using it for a while. Excellent bang for the buck power wise but a Rotel RMB-1075 with less power was a more refined and better amp. Gen 2 was a bit more refined because they toned down the gain and reduced the noise floor. Gen 3 is a different design entirely because it's modular but I haven't owned one of those.
    I have a couple of Outlaw multi channel amps for home theater channel use and have absolutely no complaints about those.
  • recoveryone
    recoveryone Posts: 929
    Its about time I hear people bring up the fact that having extra power is not about more wattage, but being able to have reserve power to cover the high peaks and very low passes without damaging the drivers in a speaker. People commented on why I use two Crown amps in my livingroom setup with my R700's. Some felt it was over kill, but fail to understand you may never want or need to play your system at such a high level but give your speakers the much needed power during peak passages to not damage the drivers.
  • Emlyn
    Emlyn Posts: 4,708
    Congrats! I have a pair of R600 and was really surprised at the kick those things have given their relatively small size. No subwoofer needed given room size constraints. R700s would have been too big for the room I have mine in.
    Polk engineering magic!
  • PSOVLSK
    Congratulations on the new speakers and amp. I never get tired of posts like this where someone gets new gear and it exceeds expectations. Glad you’re loving the new setup.
  • Milito
    Milito Posts: 2,003
    Congrats on your new setup, I'm glad it has exceeded your expectations.
