White Speakers
Zombiequeen17
We purchased the Polk ES20 speakers. Does anyone sell white grille covers for them? The black covers are nice but stand out too much. Thanks!
Best Answer
I think most manufactures stopped offering white cloth because it ages poorly- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Answers
Do those have plastic grill frames?
@pitdogg2
Yes they have plastic grill frames. I think my fiancé is gonna try and make them in white. We wanted it to blend in in the back of the room. -
Well then that makes it more difficult to just buy new cloth.
Amazon, e.g., offers myriad grille cloth "opportunities". Quality is likely all over the map, but something on the white spectrum (so to speak
) should be available with some patient sleuthing.
Might even be worth checking someplace like https://www.madisoundspeakerstore.com/ or even https://www.parts-express.com/
Doc, you cannot just staple new cloth to the plastic frames like the older MDF frames. It is likely welded(melted) to the frame. I'm not sure it is feasible for the dyi'er.
Finding the cloth is not the issue. -
hot glue + fabric = super adhered- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
