Vintage Monitor and SDA Speaker Deals
All that Denon gear has the wood sides & the speakers from what is pictured looks greatRandy-Maine
2ch-RTA15tl crossover upgrade
by David WMG
Yamaha cr1000 cr2040
HT-Yamaha Parasound Acurus
Yep I bet it's a treat to listen to. Nice to see things for sale in their environment as well, not just a pair of speakers on a table like a lot of sellers in my area.
I may have these in my garage if anyone is interested.
Conradicles wrote: »I may have these in my garage if anyone is interested.
Location? -
Hickory NC possibly (one of the FS threads)Randy-Maine
by David WMG
Hickory. Not sure what I am going to do with them yet. Might update the crossovers.
These are SDA-1B I think but I'll verify when I get them opened up.
Looking at the blade/blade socket I'd tend to agree. If they have 4 mw6509 that will seal the deal.
Polk Audio Legend L800 SDA Floor stander Audiphile Speakers
$3,000 Listed 32 minutes ago in Douglasville, GA
https://www.facebook.com/share/1C1N4SJ2Mk/"Sometimes you have to look to the past to understand where you are going in the future"Harry / Marietta GA -
SDA2a Pair - $225 OBO (Toledo, OH) Claimed excellent. No affiliation.
https://toledo.craigslist.org/ele/d/toledo-polk-audio-sda2a-speakers/7853557935.html
Boston - CR7, CR6s, CR4s.
Thompson Adventures, Inc. -
Well I'm not sure those are SDA 2a. I've never seen the SDA 2a in that cabinet configuration WITH a pin/blade socket.
According to SDA Handbook based on the cabinet design (fig 3.8) and the pin/blade connector they would be 1987 or 1989 version SDA2B's depending on having polyswitches in the crossover.
Definitely 2B’s -
Those look like the ones I bought new in 86 or 87. They had a large "A" sticker after the "SDA2 on the back of only one speaker the other speaker just said SDA2.Gustard X26 Pro DAC
That's odd, I have never seen an sda2a with that cabinet style. -
Probably one of those transition between A and B but they were labeled A. They were blade/bladeGustard X26 Pro DAC
2Bs? - $200 (Appleton, WI) Stains on top. No affiliation.
https://appleton.craigslist.org/ele/d/little-chute-vintage-polk-audio/7861595908.htmlExpect that there will be bumps in the road. Choose to not let them rattle you.
Those stains are pretty deep & the side panels look like they need attnRandy-Maine
by David WMG
Yeah those tops are veneer... That's not sanding out- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Early Monitor 5's with peerless tweeters in the Great Northwest. They appear to be in very nice overall condition for a mere40 dollars.
No affiliation.
https://spokane.craigslist.org/ele/d/otis-orchards-polk-audio-speakers/7861477506.html -
road trip!
Dang...they are MINTY.
SDA-CRS for $50.
https://www.facebook.com/share/1LcRaY8bNq/ -
LSI9 + Jamo surround set - $400 (Gulph Mills, PA) No affiliation.
https://philadelphia.craigslist.org/ele/d/villanova-surround-sound-set-polk-lsi9/7861680679.htmlExpect that there will be bumps in the road. Choose to not let them rattle you.
https://www.facebook.com/share/15uVmCTraD/
No Affil.
Any idea what this configuration is attempting?
The speakers are Monitor 10's, the terminal cups are labeled SDA II have two fuses and an SDA connector. There has been another MW installed in the rear panel.
aprazer402 wrote: »https://www.facebook.com/share/15uVmCTraD/
No Affil.
The original SDA II was a 3 driver speaker. I can only speculate the the bottom driver was a bass driver. The top two drivers were 1 stereo and 1 dimensional. It was a blade/Blade interconnect in which both blades carried signal. What that mess is, just that a mess. The rear woofer may be the bass driver. I do not see two connectors for the interconnect with that 3rd binding post.
Frankenpolk -
Either the right or left channel is out in their stereo?
SDA2 Pair - $100 (Houston, TX) No affiliation.
https://houston.craigslist.org/ele/d/houston-vintage-polk-sda2/7866131727.htmlExpect that there will be bumps in the road. Choose to not let them rattle you.
