About to unleash the next sda srs beast
VR3
I tease you with this cheesy AI image
The standard c coil versus the biggest they can fit in the machine
- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
You using the big one on SDA's?
Yes, I've actually used it a couple other times but it's quite a bit more than the standard.
I used it on the big duelund build a while back, worked very very well- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
It meets all the parameters? What does it drop the ohms to?
There's honestly not much difference, the dcr rating of the standard c coil is so low already, it's just a little bit lower.
Similar, I can't recall what the set Sean's read at but I had no issues driving them with a tri Vista integrated to very high levels cleanly with insane bass.
Polks directive on the sda inductor was the lower the dcr the better performance but harder to drive.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
My 2.3tl's run about 2.5ohm at the post, crazy good with the Aragon..
Yeah the number 2.8 comes to mind- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Just finished wiring one up!
Another teaser for fun 😍
**** teaser....
Ok ok one more
Wowsers!
Never seen a heatsink on an SDA XO. Cool
Mundorf resister needs a heat sink.
I've installed path audio resistors to a heat sink and there are definitely performance gains, especially if you listen at louder volumes.
I've found alot of benefits of using heat sink based resistors in parallel circuits as they tend to run alot hotter than series resistors.
Most resistors will increase in value as they become hot. If you are ever listening and feel like your sound seems more dampened than the beginning that could be the cause
Here's the slab of marble wood I cut up, planed and used for part of this build. I didn't snag a photo of the bubinga slab but both species is very difficult to work with.
I will 100% verify the above comment regarding listening at high, I mean high, volume at sustained periods, from personal experience I speak.
The music starts to take on a transistor radio type of sound. The first thing you'll notice is bass impact will start to decrease the louder/longer you crank.
This has nothing to do with an amplifier running out of juice, it's exactly what VR is saying. It's the heat build-up of components in the crossover that's the cause.
Most folks will never experience this as most don't listen to their system this way. Most don't punish their system's like some of us do.
It's a weird thing that all of a sudden you wonder what's happening, hard to explain.
You eliminate these things when you don't build to a price point.
Carry on (Sir) building these masterpieces and raising the bar.
Skip -
Thank you
Also this eventually will cause resistors to drift in value permanently so if you experience this on a regular basis you should highly consider introducing a heat sink to the build- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Thank you- that's really helpful to have awareness of.
When I rebuilt my grandes, the difference in sound quality over say a 3 hour session at 85db nominal with a heat sink crossover versus normal was night and day.
The composure of the sound stayed unchanged and using a temperature gun showed the resistors never went above room temperature even 3 hours in.
On the opposite side of the spectrum, the parallel resistors for the midrange were burning the substrates of the oem crossover.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Tweeter network
Clarity cmr
Clarity csa
Path audio and mundorf resistors
Jantzen inductors
Supra rondo
Mid /sda
Clarity cmr
Clarity csa
Jantzen inductors and 12 awg c coil
Supra rondo
Point to point wired
Marble wood and bubinga substrates, backed with mdf and laser cut
Supra quadrax sda cable
Wbt binding post
More pictures
Once again, another work of art.
Thank you 😁- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Pretty work. I hope you're using audiophile zip ties
Absolutely gorgeous work.
Would love to hear these installed. -
Thanks guys!
I store my zip ties in the freezer to improve performance!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Looks great!Mojo Audio Illuminati v3>>Quantum Byte w/LMS>>Rpi/PiCoreplayer>> Starlight 7 USB >> Mojo Audio Mystique v2 SE>>ModWright SWL 9.0 SE Signature>>Hafler DH-500 Amp+ (Musical Concepts Fully Modded)>>
1KVA Dreadnought
Marantz SA 8005
Sony PS4
"All THAT IS LOST FROM THE SOURCE IS LOST FOREVER" -
I'm just speechless! Wow! Awesome work!--Gary--
"Sometimes you have to look to the past to understand where you are going in the future"Harry / Marietta GA -
Thanks everyone! I'll send a video of them playing this weekend 😁- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Sign me up for the SDA SRS Beast® Road Test.
