BNC to RCA adapter or proper cable
Now that I have a Lumin D1, I want to experiment and compare. From my understanding, the internal DAC in the D1 is no slouch, but I also have the Tri Vista 21, so I want to compare the two in my system. The Lumin D1 has a BNC digital output and I don't have a cable that has BNC, only RCA. I remember Tom having a nightmare experience using a BNC adapter, so I'm hesitant to use one. Any suggestions for where I can get a quality, low cost (under $200), digital cable with BNC on one end and RCA on the other?
    VR3 Posts: 29,550
    edited June 2025
    Bnc 1.5m is the way.
    It is better to send a piece of gear off to have a bnc connector installed, imo
  • newbie308
    newbie308 Posts: 811
    So, based on that suggestion, should I replace the RCA connector on the Tri Vista, or have a BNC added?
    treitz3 Posts: 20,119
    Get the proper cable and do not use an adapter. Adapters cause issues.
    That said, if it is only for testing, in this case, I don't see any issue with using a cheap $7 adapter from Amazon. Just keep in mind, the sound might be altered slightly and it may or may not work.
  • PSOVLSK
    PSOVLSK Posts: 5,400
    VR3 Posts: 29,550
    edited June 2025
    Imo, if I wanted to rock a tri Vista dac as a daily driver I would have it sent to a tech like parts connection and have them check it out and replace the coax to a bnc.
    The tri vista is a great dac but it is getting old at this point so having it sent for a general service would be money well spent
  • tonyp063
    tonyp063 Posts: 1,137
    Here you go.
    https://www.ghentaudio.com/products/e09?VariantsId=15653
    Custom made to the length you want & made with quality materials.
    And not a bajillion bucks.
    fwiw
    I have done business with this guy before, for other types of cables, and have been quite satisfied all around
  • newbie308
    I appreciate the info! I actually took up Paul on his offer. I have never been disappointed with any of the cables that I purchased from @marvda1 , and the one @PSOVLSK offered is just that, apparently. Thank you!
  • PSOVLSK
    newbie308 wrote: »
    Yeah, Marvin knows good sound. I trust his ears. Only selling this because I’m not currently using a cable like this. I’ll probably regret selling it when/if my system is back to normal.
  • pearsall001
    pearsall001 Posts: 5,328
    edited July 2025
    I have a Chord Quest DAC that has BNC connectors & I use a BNC/RCA adapter with no issues at all. RCA cable from Qutest using BNC adapter to pre. Works just fine.
    Post edited by pearsall001 on
